I'm using VDJ 5.2 with the mixstation skin. When I play videos at home, I can move and resize the video screen that pops up in a seperate window. The last two times at the club though the screen completely disapears if I try and move or resize. It's done this with two different laptops. I use the same setup at both places. Any ideas of what might be the cause?
geposted Mon 03 Nov 08 @ 3:53 pm
Instead of dragging the screen over, just go into Cnfg, Video and u will see where it says Window click on that and you should see your video card in that drop down, if so click on your vid card and activate, you will then have full screen on your second output.
geposted Mon 03 Nov 08 @ 8:28 pm
