so i got the 64-bit driver for mk2 i got everything down n ready to go,BUT i click on the icon and then a "direct X sound driver error" shit pops up????? WHAT do i dooooo??????
geposted Mon 03 Nov 08 @ 4:15 pm
Help!!!!!!!!please.
geposted Mon 03 Nov 08 @ 7:02 pm
Hi!!
You better use ASIO mode for the MK2.
Look in my BLOG.
Hope this will help you.
Look in my BLOG.
geposted Mon 03 Nov 08 @ 7:04 pm
Nope nothing............i installed directx and it says i have a newer or eqilalent version so i dont think its that.........................if i dont get this straightened out im going to destroy my new laptop........help please
geposted Mon 03 Nov 08 @ 9:02 pm
The Mk2 driver is a little basic, it relies on the control panel's setting, it's currently in ASIO, change it to WDM.
geposted Mon 03 Nov 08 @ 9:05 pm
it is
geposted Mon 03 Nov 08 @ 9:10 pm
BTW i have a hp laptop,vista,64-bit,pavilion dv4,i dont know what direct x it has,i lost my installation cd for my mk2 so i downloaded it from the download center, i downloaded the 2008 hercules vista driver, i just bought this laptop and its the first time i use vista, and after installing VDJ home edition off the download center and the latest hercules driver, i get a "direct x sound driver error"...........i need help fast and im going crazy : ) lol
geposted Mon 03 Nov 08 @ 9:20 pm
c'mon please?
geposted Tue 04 Nov 08 @ 3:17 pm
OK, I went into my crappy computer and checked everything that could go wrong. What version of VDJ are you using - DJC or Home edition? It makes a difference on what advice we give.
It's not your computer by itself...
geposted Wed 05 Nov 08 @ 4:09 am
im using the Hercules MK2 with DJC version, the one that came with the MK2.
geposted Wed 05 Nov 08 @ 3:31 pm
Mi amigo, I tried everything including installing old drivers and I can't recreate that error... maybe it is the the 64 bit computer. Once again, only guessing.
geposted Thu 06 Nov 08 @ 1:17 am
hmmm you think getting virtual dj pro OR the Hercules RMX it will work perfectly or okay? Thanks BTW
geposted Thu 06 Nov 08 @ 3:24 pm
In your Version of VirtualDJ (3.4.1 I think) do you have a sound setup tab.
If yes, can you see a little box that say's something like "apply Eq on external controls" or something like that.
If it is checked, Uncheck it. Shut VirtualDJ down and restart it.
geposted Thu 06 Nov 08 @ 3:34 pm
