Can someone tell me how i can install the new transitions or even plug ins once i have dl'd them?
Thank you!
Thank you!
geposted Mon 03 Nov 08 @ 11:49 pm
hope this will help in how to use plug ins and transition, basically load your plugins to the correct folder ie: either into to transition or video effects you will find them in docs/vdj/folder. after downloading you must install the effect by double clicking on the red install box, afterwards open up vdj > effects .video transitions and select which one to use and activate, personally i just select the random video transition and let the programme run itself throughout the night. remember to always activate an effect, below is a quick guide on using other types of plug in.
remember to have your vids stored where they are accessible for clipbank as they need to be in the same location each time you open up VDJ
geposted Tue 04 Nov 08 @ 10:50 am
