I just purchased VDJ home edition- installed- registered the product. When I download a new skin(from the download center) it comes in EFW. Format and I can’t do anything with it. I notice in the trial version there was a folder called skin and that’s where I could find the files. When I open my VDJ I find a exe. And the uninstall file along with crash guard and two readme files. AM I missing something?
Any help would greatly be appreciated
geposted Tue 04 Nov 08 @ 2:06 am
It's extrange, because the skin files comes in .exe format.
You have to execute and it install on the correct folder.
Are you sure you are downloading the skins from HERE?
geposted Tue 04 Nov 08 @ 8:19 am
geposted Tue 04 Nov 08 @ 8:28 am
You can thank your anti virus software for that.
http://www.fileinfo.net/extension/efw
I would try renaming the extension or disable the anti virus software and re download the skin.
geposted Tue 04 Nov 08 @ 8:46 am
