The problem i'm having is this i started up my virtual dj this morning and none of my functions are working like the volume the jog wheels nore anything else but i can play a song on the left side though and thats it. I went into the config to see if there was anything out of the ordinary and everything seems to be ok i even made sure the console was activated and all i have no idea whats wrong even all my wires are properly plugged in so it cant be the soundcard can someone try and help me?
regards james
regards james
geposted Tue 04 Nov 08 @ 11:48 am
Try the ASIO mode.
You can see it HERE in my blog.
Good luck.
Good luck.
geposted Tue 04 Nov 08 @ 6:50 pm
