Basically what i would like to know is if there is a way to separate the channels of VDJ independently
What I am trying to do is to run each individual deck into separate channels onto a Korg Km402 Mixer, so that i can cue and cross fade between deck 1 and deck 2 and also control the effects of each channel independently. Is this possible and if so whats the best way to achieve something like this? Please help
geposted Wed 05 Nov 08 @ 8:26 am
Yes, VirtualDJ has a sound setting that provides this capability.
geposted Wed 05 Nov 08 @ 9:29 am
sorry about the double post..i tried to delete the other one cus it sounded kinda confusing but i couldnt find where to do so....can you elaborate a little bit more on how i would achieve this?..would i need to get an external soundcard to make this possible??
geposted Wed 05 Nov 08 @ 9:57 am
You can use external or any other card that has at least 4 channels (2x stereo) which can be found on any motherboard today. You can use computer only or have two separate outputs like on CD players which you can connect to external mixer.
geposted Wed 05 Nov 08 @ 10:42 am
Config>Sound Setup>Left Deck Outputs 1&2 Right Deck Outputs 3&4
geposted Sat 08 Nov 08 @ 11:59 am
wrong message sorry
geposted Sat 08 Nov 08 @ 1:19 pm
