Hi all,
I just bought a new VCI-100 and d/l'd a trial version of VDJ. I can't seem to get the VCI-100 to scratch. The touch-sensitive platters only pitch-bend. The vinyl mode button is illuminated and working in traktor. I just hate traktor. :) Is there a fix for this? Thanks.
geposted Thu 06 Nov 08 @ 4:30 pm
To elaborate, I can scratch when a deck is paused. But when a deck is playing, all I can do is pitch bend if I touch the metal touch-sensitive part. Spinning the outside plastic wheel doesn't do anything. I think the vci-100 is fully supported and mapped, so I think it may be my setup. My console works in Traktor, so there's nothing wrong with it. Please help. Cheers!
geposted Fri 07 Nov 08 @ 10:31 pm
do you have it on scratch on your VCI 100??
geposted Thu 13 Nov 08 @ 9:58 pm
two things....
make sure the version of virtual dj u downloaded is 5 or higher...
as for the mapping....to scratch use "scratchwheel" and the key is "Ctrl 16-19" (depends on which wheel and vinyl mode). for pitch bend use "pitch_bend" and the key is "Note 58-61"
geposted Fri 14 Nov 08 @ 6:14 am
Hmm, so I have to map? So much for full support out of the box. I'm using 5.2 and the console is set to vinyl mode. Thanks for the responses, but I think I'll try out Traktor.
geposted Sun 16 Nov 08 @ 11:45 am
Yeah i'd agree that the native support of the VCI 100 needs some work.
geposted Sun 23 Nov 08 @ 10:42 am
