I have been using the Hercules MK2 for a while and 2 days ago I bought the Hercules RMX. Very satisfied with it and its new features. But What happened to the Samples selection? What about the 1, 2, 4, 16 Tempo Looping? Well not that I used those all the time but why take them out? Am I missing something?
geposted Fri 07 Nov 08 @ 10:06 am
i think you can access all of these features if you plugin the correct skin
geposted Wed 12 Nov 08 @ 2:35 am
@ DJ-TURBO
You version is "LIMITED", this is the simple reason, you can buy the PRO versione with special price
http://it.virtualdj.com/forums/87892/General_Discussion/_NEWS__Special_PRO_version_discount_price_for_Hercules_DJConsole_RMX___Steel_(Limited_edition_users).html ;)
@ adamjmeek
In DJConsole version skins can't be changed.
@ adamjmeek
geposted Wed 12 Nov 08 @ 6:30 am
Versions 3.x and 4.x has that function, but in V5.x does not.
I has had the same question like you, but you only have to change the way of mixing.
When you got it, you will notice it's a better way that 1, 2, 4... loops.
You don't have to choose the loop length, you make the length.
geposted Wed 12 Nov 08 @ 12:54 pm
@ cioce: thanks for your help with the rmx config posts...i finally have it all worked out.
@ turbo: limited edition is just enough to get your mouth watering for the pro version. its worth it.
geposted Wed 12 Nov 08 @ 9:06 pm
Good Deal. I didnt know about that discount. I will get it next paycheck lol. Thanks
geposted Wed 19 Nov 08 @ 7:52 am
