Well im ganna get more amps and speakers..well currently i have pro pyle amp of 3000...and two pro pyle speaker with two 15 in woofers a tweeter horn and 5 small tweeters..well im thinking of getting more 2 more speakers but this time some sub woofers...i want to connect the amp i have with the new amp i wanna get...What kind of amp should i get??My sound card i have has only one channel output which i connect to my current amp.. and the other output is for monitoring purposes..Or do i just buy a sound card with more outputs so i can connect them to more speakers??
geposted Sat 08 Nov 08 @ 12:55 pm
Ok I'm lost here.... what does a sound card have to do with power amps and speakers?... (Time to bring in the smart boys)
geposted Sat 08 Nov 08 @ 3:07 pm
if you get powered speakers you can chain the speakers
geposted Sat 08 Nov 08 @ 9:55 pm
How do i chian tha speaker???Thanks in advance..
geposted Sun 09 Nov 08 @ 10:16 am
Sorry Dj renne...i dont make sense most of the time...then thats when the smart boyz jump in..HEHEHe..OH YEAH IM FROM FLORIDA TOO..
oh yea can u give me some names of some good power amps too..THANXXX
geposted Sun 09 Nov 08 @ 11:52 am
most PRO amps have a pass-thu on the input.
this means you can add another amp to your system.
although, if you have a set of bass bins, and a set of full range speakers, i would not recomend using this 'link' option.
there is something called an 'electronic crossover'
this is usually a 1u box that fits in your rack and it splits the sound into a bass output and high output.
then you get your 2 amps and connect them to the outputs on your crossover...
some more infor here...
http://www.scrounge.org/speak/xvrprim.htm
geposted Sun 09 Nov 08 @ 12:53 pm
a power speaker has a spot on the back that you plug in another power speaker...
geposted Sun 09 Nov 08 @ 4:05 pm
ok checked it out but it was kind of complicated..do u know where i can get some pictures of that kind of amp????
geposted Sun 09 Nov 08 @ 9:10 pm
Dude,
You will need 2 amps AND a crossover to do what I think you are trying to do.
You have one amp now. You need ANOTHER AMP.
You also need a CROSSOVER.
A crossover separates the bass from the mids and highs. With a crossover, you can have only bass sound going to your bass bins and all the mid and high sound (voice and music) going to the main speakers. Both amps will connect to the crossover. ONE amp will get only HIGH an MID RANGE frequencies, the other amp will only get BASS frequencies.
So.....
One amp for pretty much full range sound (high and mids). You will plug your main speakers into that amp.
The other amp will deliver only bass sound so you will plug your bass bins into that amp.
Understand?
So.....
Understand?
geposted Mon 10 Nov 08 @ 2:42 pm
OOOOOOOOHHHHHHHHHH...now i do..sheesh no need to get fiisty...hehehehehehe..JUST PLAYin Thanks bro..you know i feel like i read that off a page from the book "AMP CONNECTING FOR DUMMIES"hehehehe..im saying
geposted Mon 10 Nov 08 @ 2:46 pm
Good luck.
Happy I could help.
Any questions, just hit me up.
Happy I could help.
geposted Mon 10 Nov 08 @ 2:57 pm
got it thanks..
geposted Mon 10 Nov 08 @ 2:59 pm
