Ive been trying to broadcast my music online but it always says "encoder error". How do i fix this?
Thanks in advance!
Thanks in advance!
geposted Sun 09 Nov 08 @ 5:54 am
Someone help me please. I'm trying to broadcast on listen2myradio.com and did everything right but it says "Encoder Error", how can i fix this?
geposted Mon 10 Nov 08 @ 10:01 am
its your lame_enc if it isnt in the correct folder you cant broadcast!
geposted Sat 15 Nov 08 @ 4:06 pm
How can i fix that? Which folder should i be using?
geposted Fri 09 Jan 09 @ 2:10 pm
TRY This:
http://pcsupport.about.com/od/findbyerrormessage/a/lame_encdll.htm
geposted Fri 02 Aug 13 @ 1:21 am
I think he's probably fixed it by now.......or given up.
geposted Fri 02 Aug 13 @ 6:14 am
As above, this is an old topic from 2009 that's over 4 years old.
Please check the dates before posting.
The user has most likely solved the problem by now.
[Old topic closed]
[Old topic closed]
geposted Fri 02 Aug 13 @ 6:40 am
