Hi there could any one help me on a few things iv recently changed lap top and upgraded from ersion 4.0 to 5.2 pro virtual dj. The first problem i have im running pioneer cdj,s 800 with maya 44 sound card. for some reason i can still hear the oppersite channel to he one playing very slight through my speakers when using the cross fader and channels. mixer is fine so that eliminates that av lowered the output and imputs in my asio sound card but means i have to turn volume up on mixer lot more and the sound quality aint that good. but was perfect on my last lap top and using version 4.0 and still using all the same equipt. had a look in sounds setting but honestly dont know what its is. the next problem is the cue button on the cdj,s im using the same time codes as version 4.0 but when i press cue when a track is playing its noe sending in back to start on track even with no cue points selected was working fine on version 4.0 iv used both types of time codes but no change.and the last problem is on my vesion 4.0 where i have all my music folders down the left side there 2 folders at the to local database and global database. when i click on local database it would bring up all my music in all my files so i could surf and search all my music at once through instead of clicking on each folder. on my new softwere 5.2 i dont have local database and do know how i can surf throug all my music in virtual dj instead of having to search every folder for my tracks. would be very grateful if someone could get back to me on these problems thanks.....Darren!
geposted Sun 09 Nov 08 @ 9:26 am
If you could please register your copy of Virtual DJ.
That will let it be known if the problem is in the settings or if you are having these issues because of cracked software.
Illegal (cracked) versions of VDJ cause various problems and issues that can not be solved on the forum. Registered versions of VDJ can be investigated and solved.
geposted Mon 10 Nov 08 @ 6:25 pm
Please, register your serial number or we have to think you have a ilegal version, and you will not get support here.
geposted Mon 10 Nov 08 @ 6:40 pm
