Wats up eveyone in dj land i have a question maybe someone can answer. Can i use my Hercules RMX in conjunction with a Stanton DaScratch. I really want to get a dascratch because i think its a real great idea and i think it will look nice beside my rmx but i want to know if they can compliment each other or if they work together and also if someone has made the midi presets for the dascratch because i see in the forums that people are having trouble setting it up with virtual dj.
geposted Sun 09 Nov 08 @ 4:22 pm
No, It's realy easy,
You choose in Darouter GEN Single SCS.3d V1.00
In vitual DJ, you create your own configuration in MIDI config like a keyboard controller.
BE CAREFULL : Some faders are absolute or relative, you can see the preset mapping of the dascratch on Stanton.com
And You MUST select the same attributes in VDJ, like that you can by example, use your jogwheel as a crossfader...
geposted Mon 10 Nov 08 @ 11:42 am
I've had a got with da-scratch and there crap.
geposted Tue 11 Nov 08 @ 6:56 am
yea thay i are baught one and gave it back the next day i couldent get a refund so i got store credit so instead i got some nice pioneer dj headphones and a microphone lol
geposted Wed 12 Nov 08 @ 7:44 am
I am using mine with ICDX and or my VCI100, i have it set to only control video functions such as cross fades and clip bank... otherwise i would probably send it back as well... I told Stanton they need to get off the Serato / Traktor DJ band wagon and should have had this mapped when it was released... The person who wrote back agreed and said presets were being worked on...
we will see, i wont hold my breath... ;-)
geposted Fri 14 Nov 08 @ 1:38 pm
Lol,
I have hard finished to map my stanton with my control steel : All my stanton is mapped ! all button, sliders, are in use. Now i can hardly use VDJ without mouse and keyboard :>
Yet I finish, I will post my preset.
And don't forget that in the future, we will also can change the generic presets of the dascratch :)
geposted Tue 23 Dec 08 @ 9:04 am
DASCRATCH A B
S1
S2 Sample Volume Sample Volume
PLAY Set Cue 1 Set Cue 2
CUE Play Cue 1 Play Cue 2
SYNC Set Cue 2 Set Cue 3
TAP Play Cue 2 Play Cue 3
VINYL B11 Video Transition 1 Video Transition 5
B12 Video Transition 2 Video Transition 6
B13 Video Transition 3 Video Transition 7
B14 Video Transition 4 Video Transition 8
C1 Video Crossfader Video Crossfader
S4 Video Slider 1 Video Slider 1
LOOP B11 Loop 1/4 Loop 1/4
B12 Loop 1/2 Loop 1/2
B13 Loop In Loop In
B14 Loop Out Loop Out
B1 Loop 1 Loop 1
B2 Loop 2 Loop 2
B3 Loop 8 Loop 8
B4 Loop 16 Loop 16
B5 Loop 4 Loop 4
TRIG B11 Rec Loop Rec Loop
B12 Rec Jingle Rec Jingle
B13 Stop All Sample Stop All Sample
B14 Play Sample Play Sample
B1 Sample Select 1 Sample Select 1
B2 Sample Select 2 Sample Select 2
B3 Sample Select 3 Sample Select 3
B4 Sample Select 4 Sample Select 4
B5 Sample Select 5 Sample Select 5
FX B11 Effect Button 1 Effect Button 1
B12 Effect Button 2 Effect Button 2
B13 Effect Button 3 Effect Button 3
B14 Effect Button 4 Effect Button 4
S3 Effect Slider 1 Effect Slider 1
S4 Effect Slider 2 Effect Slider 2
S5 Effect Slider 3 Effect Slider 3
EQ B11 Effet Button 5 Effet Button 5
B12 Effet Button 6 Effet Button 6
B13
B14
S3 Effect Slider 4 Effect Slider 4
S4 Effect Slider 5 Effect Slider 5
S5
S1
B13 Loop In Loop In
B1 Loop 1 Loop 1
B2 Loop 2 Loop 2
B3 Loop 8 Loop 8
B4 Loop 16 Loop 16
B5 Loop 4 Loop 4
B13
B14
S5
geposted Tue 23 Dec 08 @ 10:51 am
Arf ... I can't display cells ...
geposted Tue 23 Dec 08 @ 10:52 am
Can You please share Your settings?
geposted Fri 05 Mar 10 @ 3:30 am
search the forum for DaScratch mappings. Sigifigant progress has been made in the functionality of these things. They are now a vital part of my DJ setup.
geposted Mon 15 Mar 10 @ 2:51 pm
I recently upgraded to VDJ 6 and installed latest drivers for Hercules DJ Console RMX and the mixer still won't work.
It worked on previous 5.0 version
any suggestions? I'm running Vista
geposted Tue 16 Mar 10 @ 4:59 pm
did u uninstalled the drivers, restarted pc, and then installed drivers again? i have vista & w7
geposted Thu 18 Mar 10 @ 3:54 am
