Hey guys...
Do I have something wrong in my config? When I record myself it always comes out way low in volume. I have recorded a few cuts and breaks only to bring them back into the mix and the volume is all jacked up. I have the thingy thing set to where it will auto match the level of every song but it only seems to work with larger files.
Any hints?
Any hints?
geposted Mon 10 Nov 08 @ 5:35 am
Not sure what you want to do, but if you are recording a mix try to volume up Record slider in System.
geposted Mon 10 Nov 08 @ 6:18 am
I am not sure what you mean.
I thought I had it already up as far as it would go.
So this does not happen to you guys?
Alf...good to see you. I should be in your neck of the woods soon. It would be cool to see you again......if I have the right one anyway.
Thanks for any more help.
geposted Wed 12 Nov 08 @ 8:07 pm
