Ive been messing around trying to get numark cue to run on my setup and it seems like i get a staticky humming type sound when the music is playing.. is there any possible way to adjust cue to get more of a clearer crisp sound... i brought it to a sweet sixteen i dj'ed and ran it but it seemed muffled and also seemed low so i had to disconnect it and run off cd's again
set up:
2 pioneer 1000mk2's
behringer 4 channel mixer
serato sl1 controller box
vdj pro grade time codes
laptop:
very recent HP set up and adjusted to run best performance
numark cue v5.1
serato sl1 drivers installed
3gb of ram
ext harddrive
any ideas or any help??
set up:
2 pioneer 1000mk2's
laptop:
numark cue v5.1
3gb of ram
ext harddrive
geposted Mon 10 Nov 08 @ 11:45 am
bumpp!!
geposted Tue 11 Nov 08 @ 2:40 pm
You may have a ground loop problem
Try running of you laptop battery for a few moments to see if the humm goes away. If it does, then it is simple to sort out, but just try first.
geposted Tue 11 Nov 08 @ 5:22 pm
yeah am having the same problem,the noise goes away when i disonect my lappy power supply,i try restarting my comp but still the same thing.any other sugestions
geposted Thu 20 Nov 08 @ 7:52 am
If you don't have hum when you disconnect power adapter, you should get Ground Loop Isolator.
geposted Thu 20 Nov 08 @ 11:57 am
@damina
DJ-ALF is right, you need something like this. The ground loop isolator should cure your problem.
geposted Thu 20 Nov 08 @ 1:10 pm
