I've asked this before but nobody seemed able to help.
Basically all I need to know is what hardware do I need to be able to take a video source maybe a DVD as an input using the camera plugin.
Will this work?
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+DVD+Recorder.htm
Hope someone can help me out this time!
Cheers,
Ross
Will this work?
Cheers,
Ross
geposted Mon 10 Nov 08 @ 8:19 pm
Check My Blog on using the camera plugin with that device.
Btw make sure the device you are going to use is either XP or Vista Compliant.
geposted Mon 10 Nov 08 @ 11:00 pm
Hi Marcel!
hi I want to try playing videos for the first time, but when i open VDJ-- it does not recognize my video files. i have avi, and mpegs.
do i have to install special de-coders? and where do i get them?
and when i open the settings>codecs, it lists "video decoder" for every format...does that mean i already have the decoders installed?
thanks
thanks
geposted Sat 22 Nov 08 @ 12:46 am
Hi guys, i use the ADS Pryo AV Link. It works perfectly. I have 1 laptop output video from Cue, into NuVJ on another laptop... any input will work though, sometimes i use a portable dvd player...
geposted Sat 22 Nov 08 @ 1:30 pm
BTW, i tried the Dazzle and it did not work.
geposted Sat 22 Nov 08 @ 1:31 pm
djrelight wrote :
Hi Marcel!
thanks
thanks
Download and install K-Lite codec pack, it's free and it should do the trick. "Video Decoder" is default setting and it should work. If you have other extensions like m2v or mkv, just add them and use also "Video Decoder" setting.
geposted Sat 22 Nov 08 @ 10:13 pm
