how do you map midi on the mac version if you cant adjust the value on anything. is there something im missing of it just jacked up and i and many other have to wait for another update :(. Damn VDJ everyday is a new problem, so much potential just cant put it all together.
geposted Tue 11 Nov 08 @ 8:23 am
yes, someone please answer this
i have the same issue
geposted Tue 11 Nov 08 @ 9:05 am
You are correct the value box is grayed out in the interface. I have reported this to the development team.
In the meantime you can still add all your functionality then edit the MIDI.xml file to add the values.
Use something like the VCI-100 midi xml file (available in the downloads) as an example. Again, this has been reported to the development team.
Chris
VirtualDJ Team
Chris
VirtualDJ Team
geposted Tue 11 Nov 08 @ 11:44 am
oh, cool. thanks!
geposted Tue 11 Nov 08 @ 2:46 pm
