Is there any difference between the Virtual DJ and the Numark CUE?
geposted Thu 13 Nov 08 @ 8:55 am
This question gets asked every day LOL
Company line: same as each other, VDJ sold online, Cue sold in a box.
Users line: VDJ is better as updates are quicker and controllers are supported quicker.
That's about it unless anyone else has anything to add!
geposted Thu 13 Nov 08 @ 9:51 am
I think VirtualDJ supports more "native" controllers than than Numark Cue does, but the actually program is the same.
geposted Thu 13 Nov 08 @ 9:54 am
Cue supports all the same controllers.
geposted Thu 13 Nov 08 @ 2:25 pm
This is true , it takes longer because numark check updates a lot longer to remove any issues which appear so they can be removed.
VDJ may have more smaller updates as the issues in the earlier releases are identified and resolved.
At the end of the day they are the same great product delivered through different channels.
geposted Thu 13 Nov 08 @ 2:31 pm
OK! One problem I have experienced with programs downloaded is after a computer crash, I couldn't get the program back! Having a "hard CD-ROM" makes it easy to reload the program. Maybe burning the downloaded .exe file onto a CD-R would be the same?
geposted Thu 13 Nov 08 @ 2:53 pm
That is what I do, well sort of. I download the setup file, and save it in a special folder on a USB memory stick. That way if my laptop goes for a shit I can install VirtualDJ of the stick, I've been doing this since VirtualDJ 5rev6.
geposted Thu 13 Nov 08 @ 6:16 pm
Jimmy, that might not be a laptop your sticking that in..if it can run to the bathroom......
geposted Thu 13 Nov 08 @ 6:18 pm
LMAO!!!!
geposted Thu 13 Nov 08 @ 6:26 pm
VDJ install exe and my skins. plugins and my serial # (in my wallet) travel with me on a usb drive. This drive also has my drivers for my RMX.
geposted Fri 14 Nov 08 @ 12:33 am
I have all those things also in my handset + the manual...it goes wherever i go!
geposted Fri 14 Nov 08 @ 1:25 am
