Hello. I use 2 1200 mk2's and a djm 400 mixer. it is hooked up woth numarks virtual vinyl. it worked for a while but i just recently updated to the newest version of vv. now after a only a couple sessions...no more than 4 hours using this new version it wont read my timecodes and when i try to auto configure the timecodes in the config menu it will just crash. but this time i didnt even try to auto config the time codes i just tried to exit the config menu right away and vv crashed :(....and all i want to do was come home form work and have some fun :P. please help! here is the report.
Date/Time: 2008-11-13 20:59:47.814 -0800
OS Version: 10.4.11 (Build 8S2167)
Report Version: 4
Command: virtualvinyl
Path: /Applications/VirtualVinyl.app/Contents/MacOS/virtualvinyl
Parent: WindowServer [54]
Version: ??? (5.2.1)
PID: 233
Thread: 0
Exception: EXC_BREAKPOINT (0x0006)
Code[0]: 0x00000002
Code[1]: 0x00000000
Thread 0 Crashed:
0 com.apple.Foundation 0x9282d4b3 _NSRaiseError + 227
1 com.apple.AppKit 0x9339779f -[NSControl mouseDown:] + 1355
2 com.apple.AppKit 0x93354df3 -[NSWindow sendEvent:] + 5279
3 com.apple.AppKit 0x9356f778 carbonAppWindowMouseHandler + 244
4 com.apple.HIToolbox 0x92df14d7 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1093
5 com.apple.HIToolbox 0x92df0b7c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 304
6 com.apple.HIToolbox 0x92df7f7c SendEventToEventTarget + 56
7 com.apple.HIToolbox 0x92df840f ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1169
8 com.apple.HIToolbox 0x92df188e DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2044
9 com.apple.HIToolbox 0x92df0b7c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 304
10 com.apple.HIToolbox 0x92df7f7c SendEventToEventTarget + 56
11 com.apple.HIToolbox 0x92e3beb3 ToolboxEventDispatcher + 81
12 com.apple.HIToolbox 0x92e3a8cb RunApplicationEventLoop + 165
13 ...mixproductions.virtualvinyl 0x000b5b6a readatomhdr(void*, TQTAtom*) + 66168
14 ...mixproductions.virtualvinyl 0x00003172 0x1000 + 8562
15 ...mixproductions.virtualvinyl 0x00003099 0x1000 + 8345
Thread 1:
0 libSystem.B.dylib 0x90047dd7 semaphore_timedwait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90ce0e54 TSWaitOnSemaphoreCommon + 163
2 ...ickTimeComponents.component 0x989d7c12 ReadSchedulerThreadEntryPoint + 4723
3 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 2:
1 ...ple.CoreServices.CarbonCore 0x90d1c995 MPWaitForEvent + 221
2 ...mixproductions.virtualvinyl 0x000a5d85 readatomhdr(void*, TQTAtom*) + 1171
3 ...mixproductions.virtualvinyl 0x000a5dcf readatomhdr(void*, TQTAtom*) + 1245
4 ...ple.CoreServices.CarbonCore 0x90cb7d0c PrivateMPEntryPoint + 51
5 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 3:
0 libSystem.B.dylib 0x90009cd7 mach_msg_trap + 7
1 com.apple.CoreFoundation 0x9082c227 CFRunLoopRunSpecific + 2014
2 com.apple.CoreFoundation 0x9083d100 CFRunLoopRun + 60
3 ...mixproductions.virtualvinyl 0x0006d46b non-virtual thunk [nv:-8] to COutputMacDJC::Thread() + 6305
4 ...mixproductions.virtualvinyl 0x000a5d67 readatomhdr(void*, TQTAtom*) + 1141
5 ...mixproductions.virtualvinyl 0x000a5dcf readatomhdr(void*, TQTAtom*) + 1245
6 ...ple.CoreServices.CarbonCore 0x90cb7d0c PrivateMPEntryPoint + 51
7 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 4:
Thread 5:
2 com.apple.CoreFoundation 0x9082ba42 CFRunLoopRunInMode + 61
3 com.apple.audio.CoreAudio 0x91468356 HALRunLoop::OwnThread(void*) + 158
4 com.apple.audio.CoreAudio 0x91468171 CAPThread::Entry(CAPThread*) + 93
Thread 6:
0 libSystem.B.dylib 0x9003f6cf syscall_thread_switch + 7
1 com.apple.AppKit 0x9334f0b2 -[NSUIHeartBeat _heartBeatThread:] + 1399
2 com.apple.Foundation 0x927fa39c forkThreadForFunction + 123
Thread 7:
0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7
1 ...ickTimeComponents.component 0x98b4429b jpegdecompress_MPLoop + 79
2 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 8:
Thread 9:
3 com.apple.Foundation 0x9282fa40 +[NSURLConnection(NSURLConnectionInternal) _resourceLoadLoop:] + 259
4 com.apple.Foundation 0x927fa39c forkThreadForFunction + 123
Thread 10:
3 com.apple.Foundation 0x92856c76 +[NSURLCache _diskCacheSyncLoop:] + 206
Thread 11:
0 libSystem.B.dylib 0x9001a1cc select + 12
1 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 12:
1 com.apple.ColorSync 0x915a86db pthreadSemaphoreWait(t_pthreadSemaphore*) + 35
2 com.apple.ColorSync 0x915c2dec CMMConvTask(void*) + 60
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x008cb000 ebx: 0x9282d3de ecx: 0x90a5a321 edx: 0x15ee6110
edi: 0x1817d230 esi: 0x1817d2d0 ebp: 0xbffff108 esp: 0xbffff0a0
ss: 0x0000001f efl: 0x00200246 eip: 0x9282d4b3 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
thank you!!!
Report Version: 4
PID: 233
Thread: 0
Code[0]: 0x00000002
Code[1]: 0x00000000
Thread 0 Crashed:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
thank you!!!
geposted Thu 13 Nov 08 @ 11:05 pm
to be a little mroe specific it crashes when i press "OK" after auto configing the timecodes
geposted Fri 14 Nov 08 @ 12:24 am
Support knows about this issue. I submitted a ticket to them on September 12th, and they haven't fixed it yet. They haven't provided me with any feedback on what the problem is, or if it can/will be fixed. What I do know, this is a problem in 10.4.11. They say when you upgrade to 10.5.x it is fixed.
geposted Fri 14 Nov 08 @ 12:35 am
damn so i guess im gonna need to finally update huh...well....thanks for the quick response!
geposted Fri 14 Nov 08 @ 1:28 am
I can confirm that upgrading to Leopard remedies this problem. I had the same problem with Tiger and once I switched to Leopard the problem disappeared.
geposted Fri 14 Nov 08 @ 6:13 am
Welcome to the virtual vinyl and virtualdj TCV. It sucks.
geposted Fri 14 Nov 08 @ 10:00 pm
la verda este pinche programa es una puta mierda si no quieres tener ningun problema buscate otro diferente
geposted Thu 25 Nov 10 @ 8:39 pm
