Last night at my gig I noticed a problem with my rmx controller. Lets say I boosted the gain on the last song to +4db. (On the right deck) I then play a song on the left deck. Then I come back to the right deck and when I load a new song into it, the gain knob is still in the same place on my rmx but is reset to zero in vdj. This is causing me alot of headache along with the sensitivity or innacurateness of the gain, high, mid, and low knobs. You turn them and get no change then you get too far and the change you do get is such a drastic one. Has anyone found a solution to this problem?
geposted Sat 15 Nov 08 @ 11:23 am
Try disabling the "auto gain" in the options section of the config menu.
geposted Sat 15 Nov 08 @ 5:26 pm
Dizzyrock is correct, disable Autogain and also "EQ Reset on load" option.
geposted Sat 15 Nov 08 @ 8:33 pm
