Hey all, I just got Virtual DJ a little while ago and am still playing around with it. Overall I'm really impressed. Today was my first serious look at the AutoMix feature...
And it frustrates the hell out of me.
Having seen how the AutoMix function can automatically mix tracks (mainly at the beginning and end), I thought that I'd go in and make some manual mix points. The problem, though, is that they won't stay made. As soon as I turn on the AutoMix feature, it forgets where every in-and-out point I set (Mix Tempo, Mix Cut, and Mix Fade) was. In fact, it'll forget where they were as soon as I click "OK" to close the Edit BPM window.
And that's without ever quitting out of virtual DJ.
I can't understand if it's a problem with my inputs or the program itself. Has anyone else had this problem? If so, have they solved it?
geposted Sat 15 Nov 08 @ 6:38 pm
Okay, take that back. Upon further inspection, it appears that the AutoMix inputs and outputs do work... kind of. For some reason my Mix Cut "Entry" and "Exit" buttons seem to be wired to my Mix Fade, and I can't set the "Entry" and "Exit" points for my Mix Cut. Now what should I do?
geposted Sat 15 Nov 08 @ 7:14 pm
Why are you even opening the "bpm" window when all you have to do is click on the marker in the waveform and move the mixpoint to wherever you want.
geposted Sun 16 Nov 08 @ 9:28 am
... Wow. Didn't even try to do that. Thanks a lot man.
geposted Tue 18 Nov 08 @ 1:18 am
