So how much experience have people had with LED par cans?
I'm thinking of doing a MAJOR purchase of LED lighting (robotic and Light Bars as well) But what I was wondering about is Throw Distance.
The distance I'm going to project is around 24 feet (7.5 Meters) I have the light bars and Robotic LED lights chosen (Check out the New American DJ LED light selection BTW it's absolutely incredible)
Par 64 DMX RGB mixing is what I'm looking for.
Suggestions for best pricing? Post link please
Delivery to CANADA is essential.
Let me know what you guys think.
geposted Sat 15 Nov 08 @ 7:06 pm
Hi,
Had 4 Weidamark par 64 RGB lights for 2 years now, love them.
I run them in DMX 400 mode which allows all kinds of control from ramdom to specific desires.
They seem to have climbed a bit in price, I think I spent $130 each for them.
http://www.wiedamark.com/wdmpar64white.aspx
These are white only and I prefer the bare aluminum over painted because we all know how loud aluminum is when paint gets scratched.
They look just as good today as the day I bought them.
My buddy who has the ADJ model says his are not as bright as mine if that helps.
As for throught distance, not sure, I have them up pretty high usually.
Put it this way, you don't want to look straight at them.
geposted Sat 15 Nov 08 @ 7:18 pm
Hey Marcel, my friend Brad who is a professional lighting engineer, (has done work for Prince and the Stones for example) loves them. He claims the throw is the same, they run cooler, and last longer. He is also an American DJ lighting distributor and works their gear over real hard. He loves the new LED par cans of all sizes.....hope that helps.....
geposted Sat 15 Nov 08 @ 7:23 pm
Hi Marcel,
Greetings from Dartmouth Nova Scotia, home of the Aerobic (accident causing) Hooters girls.
I just purchased 6 ADJ PAR 36 LED light fixtures, a Microh LED Bar II and an ADj REVO III. I
used them at a wedding a couple weeks ago.
The PAR 36 cans have a throw of around 15 - 20 feet. The PAR 64 cans would be too bright,
IMHO, for most smaller gigs and venues. I have found that the Microh Bar, with its 10mm
leds, is far too intense for smaller rooms. I had to aim it towards the ceiling in order to
protect the audience. You cannot dim this fixture when it is running its own patterns or
Sound Sync. I would like to use a couple of PAR 64 lights though for atmosphere use on walls
or pillars.
I control the lights using a Behringer Eurolight LC2412 light board. I have chase patterns
set up and they sync to the beat. I can also raise a slider which over rides the patterns
and triggers the individual Sound Sync on each fixture. This is a great feature. I have
settings for Full On and Off and can trigger the internal programs on the Microh Bar. I am
disappointed that the light bar will not trigger its built in SOund Sync via DMX control.
The specs say it will but it does not. I control the REVO III using the ADJ remote control
unit.
The LED lights are great but they take a lot of work to set up and get going, especially if
you are controlling them via DMX. I hope to upgrade to computer control in the new year.
I just retired my 2 Meteor Sonalite 3000 units that I bought used in 1978. They have been in
service ever since. These are true color organs and there is nothing comparable on the
market today and that is a shame.
Anyway, my 2 cents worth. Have fun and Good Luck!
-DGee
or pillars.
unit.
-DGee
geposted Sat 15 Nov 08 @ 10:24 pm
Personally I LOVE the Acme Visio Par 64's, you use them with a controller called a colour commander, there is also a bar coming out which you can daisy chain in conjunction with the pars, the controller is superb, will try and embed a video here of the visios, they truly are great!
geposted Sun 16 Nov 08 @ 6:55 am
Hey Terry what does your ADJ guy have to say about these?
http://www.americandj.com/ProductDetails.aspx?ItemNumber=1785&MainId=2&Category=L.E.D.
The info says the output is similar to a 250 halogen bulb. If that is the case I'd be tempted to use these instead of par cans.
Would be a nicer effect.
geposted Sun 16 Nov 08 @ 1:33 pm
I'll ask Marcel..give me a couple of days..he is on tour with someone right now, I just don't know who....
geposted Sun 16 Nov 08 @ 2:50 pm
many led par cans manufacturers provide products on this site http://en.ofweek.com/manufacturer/LED-par-cans , may have you need
geposted Wed 28 May 14 @ 9:44 pm
geposted Wed 28 May 14 @ 9:45 pm
This thread is over 6years old.
Almost certainly found a solution by now.
[CLOSED]
[CLOSED]
geposted Wed 28 May 14 @ 10:28 pm
