hey guys i am new to this site and was wondering if someone would be kind enough to explain the question mark delema i downloaded some songs which i can listen using realplayer but when i try and listen to the same song on vdj i get a yellow question mark and will not play the song i try dragging the song to the playlist but it will not play any advise thanks
geposted Sun 06 Feb 05 @ 7:00 am
What kind of files did you try ? (.mp3 / .wav / .wma / .ogg)
It's possible that you have to download the appropriate codecs.
Try to surf on http://www.dbpoweramp.com/codec-central.htm and download what you need.
geposted Sun 06 Feb 05 @ 2:53 pm
if they play in real player.. they are most likely .ram or .rm, which i don't think will play at all, gunna have to get them converted methinks
geposted Mon 07 Feb 05 @ 12:01 am
Why .ram or .rm (for streaming)? Real player can read .mp3
geposted Mon 07 Feb 05 @ 12:28 am
vdj doesnt play those files does it? i know real can play mp3s, but its jus a suggestion as to why they aren't playing
geposted Mon 07 Feb 05 @ 2:26 am
dj dawson can you tell me how to convert realplayer files so i can listen to them on vdj i probably have 500 of them but they wont play thanks for the input
geposted Tue 08 Feb 05 @ 4:11 am
