I just upgraded to the latest VDJ version and I have a question regarding adjusting the CBG. It's been a while since I used VDJ, but I'm pretty sure the two of the CBG-adjusting/aligning shortcuts were ctrl+n and ctrl+m. What happened to these shortcuts?
geposted Mon 17 Nov 08 @ 4:56 am
Its still there, i have my keyboard set out with
M - adjust cbg4 -1
, - adjust cbg - 16
. - adust cbg + 16
/ - adjust cbg +1
have a look in All >
adjust cbg4 = adjusts the 4/4 pattern
adjust cbg = manually adjusts the cbg
M - adjust cbg4 -1
, - adjust cbg - 16
. - adust cbg + 16
/ - adjust cbg +1
geposted Mon 17 Nov 08 @ 11:53 pm
OK. I figured it out. I open an old shortcut xml file and just copied the shortcuts. Another question about this latest version is "where is the ok button in the BPM box after manually setting the BPM?" I go through the tapping routine, but there is no "OK" button. Does the "x" at the top right serve the same function as the old "OK" button? I honestly didn't see the bpm adjust while I was hitting the space bar, so I don't know if any changes took effect.
geposted Wed 19 Nov 08 @ 4:33 am
