Hello All,
I just downloaded the trial version of VDJ and i have a few questions regarding the timecode setup.
1) Can i use the Virtual Vinyl Timecode Vinyls to control VDJ?(easier to find and cheaper)
2) Can i operate 1 TCCD & 1 TCV at the same time (HYBRID Setup)
I just drew a blank and forgot my other questions..ill think of em..Pls if anyone can help, id appreciate it..
THANKS
THANKS
geposted Thu 20 Nov 08 @ 8:56 am
well the answer to the first two are yes you can
geposted Thu 20 Nov 08 @ 9:05 am
Thanx for the QUICK response.
I just bought the Maya44USB, a behringer Pre-Amp, and am ordering a VirtualVinyl TCV. Hope this works right the first time, but that would be TOO easy, wouldnt it...
- Is there a way to use (1) either the CDJ, or the TT to control BOTH decks, on (2) seperate channels?
If not, no biggie, just wouldve been a neat option to have.
- am I going to need to download any drivers for the Maya to make it compatible with VDJ?if so where do I find these?
As Always, Thank you for your Assistance
- 631
www.six3one.com
- 631
www.six3one.com
geposted Thu 20 Nov 08 @ 11:06 am
You can use one TCV to control both deck, yes.
geposted Thu 20 Nov 08 @ 11:53 am
How?
I just got the Maya44 today. Installed the drivers, plugged it in, and had no "real" issues. So im waiting for SOMETHING to happen :8
Still waiting on the TCV and the Pre-Amp, so i cant use the TT as a controller yet. Had a few questions regarding the current setup
- How can i use the (1) CDJ as a controller for both sides?
I can only get it to control the left deck, even when the right deck is active.
- Is there a way to route it OUT to 2 seperate channels, when using 1 IN?
Thanks, got a show tomorrow, would hate to have to point and click if i dont have 2..
geposted Fri 21 Nov 08 @ 1:13 pm
How?
**UPDATE**
I got the Maya to split the OUT into 2 seperate channels
I also got the CDJ to work on both channels BUT its very sketchy
i.e. it still wants to control the first deck even when the second deck is active
Is this how it acts in this mode, or did i forget to click something.
Tried to hit the MIDI button, started acting funny, so i unchecked it.
ANYONE?
Thanks
**UPDATE**
ANYONE?
Thanks
geposted Fri 21 Nov 08 @ 3:04 pm
You must wait for someone who use Timecode, I only know the basics as I use controller ;)
geposted Sat 22 Nov 08 @ 10:39 pm
geposted Sun 23 Nov 08 @ 5:13 pm
You can only use 1 tcv or tccd per deck.
If you route the signal to the other deck, when you touch it, you are controlling the other deck, and you need to play the timecodes to hear on headphones.
Then, you need two timecodes.
geposted Sun 23 Nov 08 @ 5:54 pm
