hey everybody does anyone know if i can connected time coded vinyl into the rmx without buying something like the M-Audio Torq Connectiv because i would really like to buy a Korg KM-202 and a pair of my cheap turntables but i wanna know this first before i make the purchase thanks.
geposted Thu 20 Nov 08 @ 10:58 pm
Yes, you can use TCVs with the MRX.
I got it and use without probs, but you need to purchase the PRO version to have full use of TCVs.
With the limited version, you only can use for 10 minutes the TCVs.
geposted Fri 21 Nov 08 @ 5:47 am
with the TCV and the rmx do i still have to use the rmx as the mixer or can i connect the tcv in the rmx and then route that into a different mixer
geposted Fri 21 Nov 08 @ 9:12 am
Your turntables should plug into input 1&2 and 3&4 of the RMX. Then you use your RMX as the mixer
But as xonor has said you only get a short time with timecodes in the limited version.
geposted Fri 21 Nov 08 @ 9:14 am
yea like 20 days lol i think i will have to upgrade but its a bummer i cant use something else as the mixer i wanted to buy a korg KM-202 and use the rmx as a soundcard so u are saying this cant be done then
geposted Fri 21 Nov 08 @ 11:53 am
No, you can use the RMX as a mixer OR a soundcard
If you want to use the RMX as a Soundcard only, then connect your decks to input 1&2, and 3&4. Then outputs 1&2, 3&4 of the RMX go out to 2 channels of the mixer.
But again you may need to upgrade for this option to work.
geposted Fri 21 Nov 08 @ 12:50 pm
I have this exact same set-up 2 citronic turntables rmx soundcard and korg 202 mixer. I am experiencing problems tho. The sound coming out of the mixer sounds very distorted ive tried turning down trim and master and nothing seems to make it sound normal
geposted Thu 03 Feb 11 @ 6:29 am
