does any one know how to completely remove the hurcules driver and all data on a mac? what are the files hidden that i should be looking for?
geposted Fri 21 Nov 08 @ 7:54 pm
ok well i found this program that uninstalls all package files seems to work. http://krugazor.free.fr/software/desinstaller/DesInstaller.php
geposted Fri 21 Nov 08 @ 8:23 pm
Go to: \YourUserName\library\preferences
find the preference file(*.plist) containing *dj* and/or *hercules* and *mk2*
delete it when know you got the right file.
I think that should do it.
Good luck!
/N
PS. I think the *.plist file's name is different depending on the versions that has been installed. DS
Add:
I was to slow... Glad you solved it!
Good luck!
/N
Add:
geposted Fri 21 Nov 08 @ 8:32 pm
