I know that VDJ supports using a single 5500 with multi layer but i really want to use 2 5500 via midi. Is this in the works?
THNX
-TM
THNX
-TM
geposted Sat 22 Nov 08 @ 5:28 pm
bump.
geposted Mon 02 Feb 09 @ 8:21 am
I haven't tried 2 units at the same time since I only have one 5500 but as long as you don't have both the units on the same midi channel you should be able to use 2 units. Have you tried changing yours midi channel on your 5500? It's found under presets mode Item #28 also make sure you set the unit number Item #29.....see page 34 of the DN-HS 5500 manual for instructions.
::::::Here's what the manual reads on page 34 in regards to your question:::::::::::::::
(28) MIDI CH Set: 1&2* / 3&4 / 5&6 Select the Midi Channel
(29) Unit No Set: 1 to 14 / ALL* Select the device's unit number. For example. if two units of DN-HS5500 are connected to the computer, set one unit to No. 1, the other to No. 2.
So what I gather from reading this is that I would have one 5500 set to midi channel 1&2 with unit number 1 and the 2nd 5500 set to midi channel 3 & 4 with unit number 2....that's just me theory, I would try it out for you but I only have one unit at this time.
THNX
-TM
THNX
-TM
geposted Tue 03 Feb 09 @ 4:59 pm
It is not supported yet. It will be as soon as possible, maybe in next update. Teamers know about that and it will be fixed. I am waiting for that too as i am just buying 5500 ;)
geposted Tue 03 Feb 09 @ 5:03 pm
Xeon,
Thnx for the update. Looking forward to getting this to work with 2 5500 and the spinning platters.
geposted Thu 05 Feb 09 @ 2:43 pm
