When I double click the icon of virtual dj it comes up a message like this:"internal database is corrupted".Should i worry about that or just skip it?How can i fix this problem?
geposted Mon 07 Feb 05 @ 10:12 pm
First close VDJ.
If you have a backup of your "virtualDJdatabase.xml" file then replace it before starting again.
geposted Tue 08 Feb 05 @ 7:41 am
Means you lost all your info on songs...bpm's comments...etc
Sooooooo if you did not create a backup Xml data file in the past ,,,well you should in the future.
If you did not have a back up just remove the corrupt file from the program(XML database folder in vdj)
Andre
Andre
geposted Tue 08 Feb 05 @ 8:39 am
Happend to me once... But it was working normally (all info there, just this message) - and it lasted for about two weeks or sth... Didn't bother me. I'm not sure what happend then, but I know I didn't delete anything, and the "problem" was gone :) Strange...
geposted Tue 08 Feb 05 @ 11:10 pm
