ok I already have virtual vinyl numark and I want to buy BCD2000.
is there an easy way to connect my vv to bcd2000, with two turntable, or two cd players
geposted Sat 22 Nov 08 @ 5:54 pm
Please avoid BCD if you can, it is very buggy unit. Why do you need sound card, you must have the one from VV package?
geposted Sat 22 Nov 08 @ 10:30 pm
I need a mix that control virtual dj with midi.
and + I already own v v numark sound card so why not using it.
do you have a better idea in which total control shuold i use? thanks something not too expensive.
why not buy the berhinger BCD 2000 what wrong with it?? is only $150
geposted Sun 23 Nov 08 @ 11:21 am
It was discontinued due to hardware faults and replaced by the 3000 which some users report the same problems remain.
Virtual Vinyl is intended for use with a mixer such as the NU04 or similar.
You could if you do not wish to invest in a midi mixer get a compact crossfader controller so you can fade the video at the same time.
geposted Sun 23 Nov 08 @ 2:24 pm
Thank you
geposted Sun 23 Nov 08 @ 6:45 pm
I have the BCD300 and if the machine you want to use it with XP then get it cuz its great i love it
if ur running vista....
STAY FAR AWAY FROM IT
But with xp its great, but im also a beginner!
geposted Tue 02 Dec 08 @ 7:20 pm
Also give a try on Numark Total Control. It's a very sweet little equipment with a reasonable price.
Or if you have CDJ's or any other DJ cd players, using time code is your best option too since you already have VV box.
geposted Wed 03 Dec 08 @ 12:46 am
I'm not really sure as to what type of problems some of you might be having with the BCD2000. Ive been using it with Virtual Dj and have not found a single glitch. I'm running Win Xp on my computer and the only problem I'm having right now, and for which I'm waiting a quick fix, is with the new version of virtual dj that has some of the commands backwards or something, but this is not a BCD problem.
If you can get your hands on a BCD2000, go for it, I'm sure, that if installed properly, you will not have any glitches.
geposted Tue 07 Jul 09 @ 6:39 pm
Im the same been using my BCD2000 from day 1 with VDJ and have not had any issues either in clubs or on VDJ Radio. I am still on 5.2.1 tho due to the glitches in version 6.0.1 that effects the jogwheels and some buttons, but i believe Moramax is working on a new Def & Xml file for the BCD2000 which will be out soon.
geposted Wed 08 Jul 09 @ 4:21 am
