VDJPedia
 Split Window
Back to Skin SDK
Skin SDK: The <window> element
The idea behind this is to allow elements of the skin to be displayed in a floating and resizable window on top of the main skin. You can choose the size and position of the window and also whether the user can resize the window on-the-fly.
In order to use the <window> element you will need to have the graphics for the window element in a separate image file to that of the main skin.
You will the use the below code:
 <window name="window" width="500" height="500" posx="11" posy="545" image="browser_windowed" shown="false">
place element code to be displayed within the window here
</window>
The above code should be familiar - the additions here are posx and posy, this is where the window should be positioned on the screen. Also the image, this is simply the name of the image file (no extension is required e.g. png).
You can use the <background> element to specify a position within the image file, for example:
 <window name="window" width="500" height="500" posx="11" posy="545" shown="false">
<background x="12" y="559"/>
</window>
Once you have included the window, you will need to add buttons in order to display or hide the window.
<button action="show_window 'window'">
This code toggles the window on and off.
By default this window will be resizable - you can use the parameter resize to disable this:
 <window name="window" width="500" height="500" posx="11" posy="545" shown="false" resize="false">
</window>
Back to Skin SDK
