geposted Tue 16 Dec 08 @ 2:33 pm
very interesting ;)
geposted Tue 16 Dec 08 @ 2:56 pm
very simple skin. Good for controllers.
geposted Tue 16 Dec 08 @ 3:16 pm
i like the 2 songs but i would chankge the spining disks in to something else this radar is too futur for me
VYNIL yeag thats goodput in a vynil
geposted Tue 16 Dec 08 @ 4:54 pm
Its not a "radar" look. Some heavy scratchers use a visual reference instead of an audio cue point. The line helps them see where they are on the track.
geposted Tue 16 Dec 08 @ 6:09 pm
Very simple. I mean its good for Timecode and Controlers. I like it :-)
geposted Wed 17 Dec 08 @ 3:37 am
some heavy scratchers dont use VDJ the real ones the old school but i think if u ot a cue poitn in audio u can se when its coming
geposted Wed 17 Dec 08 @ 3:55 am
Me too.
I like the large browser aswell.
geposted Wed 17 Dec 08 @ 8:57 am
it looks very interesting. can't wait to try it out.
godspeed listen2
godspeed listen2
geposted Wed 17 Dec 08 @ 3:28 pm
I know the purpose of the CBG is to set it (if needed) and be able to match without overlapping waves but i like to see the peaks like up also when they are next to each other also.
Does anyone think that deck#2 wave and song info text should trade places, making the red wave closer to the blue? I think visually it would make sense to have them closer. I think i might also move the CBG grid box to the bottom border just above the browser.
I am going to move some things around, I like it as is but it does not feel 100% perfect to me. Hot cues and TC mode will be added. Does anyone also care about UV meters? they are mostly for display since with external usage you really dont need them.
geposted Thu 18 Dec 08 @ 8:27 am
Yes, I think that may look better, the CBG box makes it look a bit cluttered where it is now mate.
geposted Thu 18 Dec 08 @ 8:58 am
Good opinions... I will move things around soon.
I think what you mean is to have side by side waves, i did with the original turntablist skin but found it not as useful for a visual beatmatch. one wave on top of the other works better since you can still see seperate waves but also align them up. ;)
geposted Thu 18 Dec 08 @ 9:33 am
+1
geposted Thu 18 Dec 08 @ 9:39 am
Nice skin L2;)
Looking forward to use it;)
geposted Thu 18 Dec 08 @ 1:00 pm
I am going to swap the red deck around and release this as a beta....soon.
Then with the help of those interested "we" finish
geposted Thu 18 Dec 08 @ 2:41 pm
too bad i cant use it and i have a controler..
geposted Thu 18 Dec 08 @ 3:06 pm
Are you using the Skin Creator to do all the xml of the skin?
geposted Fri 19 Dec 08 @ 5:46 am
I M ABOUT TO MODIFI THE DEAFULT VED skin just ading a EQ and a biger crossfader and i can tell you its hard as hell im doing t all by hand no MODIFIER to help me
geposted Fri 19 Dec 08 @ 9:26 am
i pretty much do it all the "hard way" I use Note pad for XML and paint.net for the images.
geposted Fri 19 Dec 08 @ 1:47 pm
Well, here's a progress report. In between getting my ass ka-kicked by a snow storm and another to follow tomorrow, I have done some work on the skin. I'm not sure i love the hot cue buttons but i might at least make them smaller. Let me know ..
geposted Sat 20 Dec 08 @ 8:09 am
