after careful consideration of this whole update thing, and weighing up the pro's and con's and taking everything into consideration this is what I surmise:
I don't care.
I don't know whats in the update, don't know if I need it or not, it could be the most perfect piece of software history, it could be a bag of shit. I dont have it, Don't know when i will have it and don't know if I will want it when its here.
So why get worked up about it
but while we are on the subject.....can you put a lock on the main pane like the side pane lock, cos i dont always use the side pane and it annoys me when it slides over.
ta
I don't care.
ta
geposted Mon 09 Feb 09 @ 1:17 pm
ta
ta
Lock the Playlist (Side pane) panel open, then slide it all the way to the right. The lock is already there.
geposted Mon 09 Feb 09 @ 1:27 pm
I don't care.
ta
I don't care.
ta
that is definitely one simple way to make urself feel better about this whole thing
geposted Mon 09 Feb 09 @ 1:39 pm
I've got an appointment with a Psychiatrist on Thursday ......... :)
geposted Mon 09 Feb 09 @ 2:38 pm
ok i know this is about updates but have you tried this one go and get your self a bunch of differnt skins by different authors
and try them out it will give you a new challenge and may even get you working with vdj in a new way i did this and from time to time
it helps to keep you fresh and on your toes about the software . on the other hand you could ask yourself this question is vdj robust and reliable , is it my working software that ceeps the wolf from the door , and can i get great help from the forums , if you answered yes to the above then dont worry your in good company chill and all will be safe . peace
geposted Mon 09 Feb 09 @ 3:51 pm
I tried that last week ..... but none of them come close to Vmix 5.4 by Matt. I've used that since the start.
Can I suggest that there is an option in the skin section to sort by resolution as most users only use one skin size and it would be helpful to search by that. Ta!
geposted Mon 09 Feb 09 @ 4:44 pm
