Hi guys.
I have a problem to program led of my Xponent
I set it to have the functions of the 2 separate deck.
For example, I mapped the "cue1" with the following instruction:
action_deck 1? video_fx_select "boom_auto" & video_fx: video_transition_select "satelliteboom"
so I actice videoFX on cue1 of left deck and I select a video transition on cue1 of right deck.
This works perfectly!
but I cannot map correctly led Cue. If I press, for example, cue1 light also led the cue2, 3, 4, and 5
to map the LED of cue1 I used the following statement:
video_fx_select "boom_auto" ? on
but this return me a syntax error.
To close :
what is the correct command that allows me to turn on the LED of the cue?
where am I wrong?
thanks and sorry for my scolastic english :)
Ciao Sischo ;)
To close :
where am I wrong?
Ciao Sischo ;)
geposted Sat 06 Jun 09 @ 4:48 am
HACKID wrote :
Hi guys.
To close :
where am I wrong?
Ciao Sischo ;)
To close :
where am I wrong?
Ciao Sischo ;)
The action statements themselves answer to TRUE or FALSE if they are active. So if I want an LED to light up when the video effect "boom_auto" is on ... then I assign the LED -> video_fx_select "boom_auto" active .. just as I would assign it to the button to activate it. VirtualDJ will report TRUE (ON) if the effect is active. OFF if not ...
geposted Sat 06 Jun 09 @ 10:45 am
cstoll can you test follow command please?
I think it's an example of bug of script language.
I tried all....but my LED_CUE1 not work!!! it's alwais OFF using this istruction!
Can someone help me?
thanks ;)
thanks ;)
geposted Wed 10 Jun 09 @ 6:15 pm
If the effect is active VirtualDJ will report TRUE or ON ... else OFF
You don't have to do the conditional test like you wrote.
btw, for others; if you simply assign the action to the LEDs VirtualDJ reports TRUE or FALSE / ON or OFF .. if that action is occurring. You do not need to do the -- > condition ? true/on : false/off < -- statements
geposted Wed 10 Jun 09 @ 7:29 pm
I also tried this istruction but does not work.
For more details i paste CUE1 right and CUE1 left istruction :
action_deck 1 ? video_fx_select "boom_auto" & video_fx : video_transition_select "satelliteboom"
now I would like that the LED_CUE1 follow the above instructions. But to simplify things I would like that it follow only the first part of the instructions....
i tried all options but the only one that turns the LED light is follows:
video_fx
but isn't good for my mapping.
geposted Thu 11 Jun 09 @ 4:29 am
