Forum: VirtualDJ Skins
Topic: My new Skin V 6 - Page: 1
Hope you like my new skin that will be ready the next day, can leave suggestions if I have to add something
SKIN_MAN_SKIN
geposted Mon 28 Sep 09 @ 10:33 am
That's a nice looking skin. I would loose the sample buttons in the middle, and add vertical VU meters. Using the v6 code the VUs can now show system output, as opposed to system gain. That is what I would like to see, other wise its a very pretty skin.
Cool skin though, but looks too bright with the white color...
maybe u could add some black to it.
Just my opinion =)
Good work!!
maybe its a daylight skin!
when it will be released to go down, pretty skin my congratulations
Thanks for the comments, I'm working on the changes undergone by you
felicidades buen trabajo amigo saludos esta chever el skin
Look The new panel
There you go! Very nice... ;-)
I hope soon to put the skin in the library
for now I leave what\'s coming
MULTI-Instac 6
Nice skin dude......
I still think that u should make one with more dark colors
Just my opinion :D
DJ ALEX
I would like to see a all white version or chrome version of the vdj6 standard skin. Is that a available ?
If you need a all white version to dj in daylight with VDJ, you can use the Skin Resizer tool.
Select the same output width and height as the input width and height.
Use "Simple Resizer" resizing option.
And in the "Options" view, select "make day skin"
This will invert all colors of the skin and make a bright white skin.
WOW...thx...this skin looks so fine....and a little bit of honor
The download link for this skin is not working...How can I download this skin? It looks great.
that means that the skin it's not available anymore.
I assumed it was not available at that location. Is it posted anywere else that you might be aware of!
Thank You!
87%
