Hello i bought the numark mixdeck and i have no idea how to get it to work with virtual dj. i have a mac and can someone please tell me exactly how to use my mixdeck with virtual dj?
geposted Thu 15 Apr 10 @ 1:18 pm
!st- Buy VDJ.
2nd-Search for Numark MixDeck Setup (in forum Hardware Technical Support). Cstoll has a great tutorial.
3rd- Download the Mixdeck Tool created by Cstoll ( You need to own the VDJ to be able to download)
Pirate software won't help you.
geposted Fri 16 Apr 10 @ 2:40 pm
This user could be using a legitimate demo version, however plugins cannot be downloaded by no licence users unfortunately.
https://virtualdj.com/forums/125388/Hardware_Technical_Support/Numark_MixDeck_Setup.html
geposted Sat 17 Apr 10 @ 1:48 am
I have the virtualdj_trial but the site keeps saying I don't have the accreditation to download the file i need to map the mixdeck. I wanted to test it on my mixdeck before dishing out the cash on VDJ6. I guess I'll stick to Traktor since I can't see do a test of virtualdj on my mixdeck. Kinda lame.
geposted Fri 04 Jun 10 @ 1:41 pm
The mapping is already part of the trial ( https://virtualdj.com/download/trial.html )... you do not need a 'special' download.
geposted Sat 05 Jun 10 @ 10:37 am
i have to say for a guy who knows nothing about mixing and mapping and all those technical words and also new to this i found that cstoll help wa very helpful, i managed to get my mixdeck to work with my vdj, the only problem is though i cannot get the both decks to cross fade.in h configeration tab i hit "external mixer" but it seems you can only assign one deck, either right or left but no option to select both, can someone help me? thx.
geposted Sun 06 Jun 10 @ 10:39 am
Did you choose things correctly ...
VirtualDJ Soundcard Setup
Inputs - None
Outputs - External Mixer
Output Drop-down - Left deck : Front Output / Right deck : Rear Output
Soundcard - 4-Out
Soundcard Drop-down - Numark MixDeck
Inputs - None
Soundcard - 4-Out
geposted Sun 06 Jun 10 @ 8:25 pm
i got it to work cstoll (hx very much)but is there any way to get it to auto start as soon as you cross the fader from one deck to another? my hdmix use to do that but this don't .iis it possible to get this feature on the mixdeck using vdj? any help would be highly appreciated,thx.
geposted Mon 07 Jun 10 @ 6:51 am
i did not see the mixdeck in the soundcard dropdown in the demo when trying to set up my mixdeck with my mac. I'll give it a second look though, when I get home from work today and see if maybe I just overlooked it. There's a chance by now my trial expired though. :\
geposted Wed 09 Jun 10 @ 1:18 pm
I am having the same problem! I'm using the trial and ive selected Numark Mixdeck under the "4-OUT SOUND CARD" i chose external mixer. Everything that was described but nothing is working.
geposted Tue 29 Jun 10 @ 3:52 pm
No matter what I keep getting the following error:
Error in the driver of CoreAudio
No matter what settings I choose for my hardware. I'm at a loss to get the mixdeck working with VDJ.
geposted Tue 29 Jun 10 @ 10:04 pm
Sorry for the double post, but I still have not found an answer to my problem. I really would like to use virtualdj if it'll work (since it supports video). I'm willing to troubleshoot it once more.
When I choose my settings I get the error in my previous post:
"Error int he sound driver of CoreAudio"
Any help?
Any help?
geposted Fri 16 Jul 10 @ 11:50 pm
I just bought numark mixdeck, anf i currently own virtual vinyl 6.0.7, and i have downloaded the right drivers for everything but only the mixer part of my mixdeck is working not the cd decks, can any body help me and fix this?
geposted Mon 09 Aug 10 @ 12:11 am
MixDeck's mixer is not midi at any part. So just decks/controllers are midi. Mixer part absolutely not whatsoever.
geposted Wed 11 Aug 10 @ 6:02 am
Hey Guys,
I have 2 questions that is happening to me I cant figure out. 1 - I have a mixdeck and downloaded the new version of 6.1, but everything works except the fader. I cant see it moving on my comp. But it does on the deck ( What do I do in that case ). 2 - why is it once I put both decks to midi the Platter lights turn off?
PLEASE HELP anything helps!!!
Robert
Robert
geposted Wed 11 Aug 10 @ 10:19 pm
Unfortunately the crossfader and the rest of the mixer section of the MixDeck is not MIDI capable and cannot control the crossfader or any other function of VirtualDJ (i.e: For video crossfading.)
It is a hardware audio mixer only. Only the decks are MIDI capable and can control the software.
geposted Thu 12 Aug 10 @ 4:37 am
i just got my mixdeck working with vdj6 trial version theres a good video on youtube how to do it.enter locomixdj in youtube
geposted Mon 16 Aug 10 @ 10:52 am
I had the same problem..had virtual dj6.0...you gotta have VDJ 6.1.2 !!!then the mappers for the MIXDECK are there!! in virtual ,look in "config" then "mappers" ,then where it says "keyboard" just to the right you'll see a small box..click that and uncheck ALL boxes..and your available control mappers will pop up , (ex. vestax,hercules,etc.) if you don't see the Numark mixdeck there,you need a newer version of VDJ!! hope this helps someone.
geposted Sat 18 Sep 10 @ 12:02 pm
Sorry, you don't have the necessary accreditations to view this page.
Why cant i view the setup tutorial??
geposted Sat 18 Sep 10 @ 5:01 pm
I get the same error message with the credentials and can't view that page.
I did get mine to work but I think if I can't find any custom mapping files, I'll start doing that myself in the settings area of the program.
geposted Sat 13 Nov 10 @ 3:11 pm
