Hey
i have the Virtual DJ LE, I downloaded some effect plug ins from this website. I got the .exe files. I clicked them, it said they were installed successfullly. However, I can't find them in the program. Clue in this newbie....
geposted Sun 27 Feb 11 @ 10:00 pm
Please do not post the same question or message more than once - You have already asked this question in the plugins forum: https://virtualdj.com/forums/143829/Virtual_DJ_Plugins/effects_plug_ins_and_skins.html
Please also do not hijack a topic that is not related to your question in any way. Your question has nothing to do with using the Numark MixDeck (You don't have this controller.)
Sorry, the software that you received with your MixTrack Pro is a free limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.) The same also applies to the VirtualDJ LE received with the Numark MixDeck.
To be able to use custom skins, effects and much, much more you will need to upgrade to the full VirtualDJ Professional. Your VirtualDJ LE entitles you to a discount off the cost of upgrading. To receive this, please go to https://virtualdj.com/buy/
You can also try out Pro features in VirtualDJ v7 Home FREE by going to https://virtualdj.com/download/free.html - This software will allow you to test your MIDI controller with it for 10 minutes at a time before reverting back to internal mouse and keyboard control only.
geposted Mon 28 Feb 11 @ 5:30 am
Okay so im thinking bout buying a mixdeck and from this forum ive gathered that the mixer isnt midi only the decks are...i prefer to use software when djing (such as traktor or vdj) and was wandering if i buy a mixdeck would that affect me in any way?
geposted Wed 20 Apr 11 @ 9:02 am
It will only be a problem if you wish to do video mixing. You won't be able to use the crossfader for video crossfading, although if you upgrade to the full VirtualDJ Professional, you can map a knob or button that you do not use on the CD players to do this instead.
VirtualDJ LE for MixDeck can be upgraded at a discount to the full VirtualDJ Professional.
Also, if you wish to record your set, you will need to use the record output on the back to the line input of your computer - See https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html
NOTE: Because it is not a MIDI mixer, the on-screen controls will not move to mirror those on the MixDeck mixer. This is not a problem for audio mixing. Simply look at where the real knobs on the real mixer are if you need to know their positions. The advantage of a hardware mixer is it will still continue to function if you get a problem with your computer. You can also use the CD players/USB media playback capabilities of the MixDeck as a backup.
geposted Thu 21 Apr 11 @ 4:56 am
ok im trying to record but i cant get my mixdeck and my virtual dj volume to work at the same time . How do i map the volume on the computer to my mix deck?
geposted Tue 17 May 11 @ 6:08 pm
Unfortunately you can't.
The mixer section of the MixDeck is a real hardware audio mixer and is not MIDI capable. It cannot control the software in any way.
Only the CD player sections are MIDI capable and can directly control VirtualDJ.
If you wish to record, please see https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html
geposted Wed 18 May 11 @ 4:22 am
i have been running virtual dj on my toshiba laptop,with windows xp,and it worked fine,i very carefully trained myself on how to do the setting,but now i just upgraded to windows 7 and my sample/play pads will not react,does anyone know whate settings to go to so i can control my sample again from my exsternal controls? iam using numark axis 8's and 9's
geposted Fri 21 Oct 11 @ 11:40 am
Please do not hijack a topic by posting a message that is not related in any way.
This topic is about the Numark MixDeck controller. Your post is regarding Axis 8 and 9 CD players.
Please open your own new topic on this subject (Click on the pen & paper icon at the top of the main topic list.)
Also, this is the Mac technical support forum. Your question is about Windows computers. Please ask in the PC forum: https://virtualdj.com/forums/20/PC_Version_Technical_Support.html
geposted Fri 21 Oct 11 @ 12:06 pm
With OSX 10.6 and higher this will help with get it recognized. I hope its not repetitive for you but it has helped others:
1. Using the “Numark Driver Remover” remove Driver version 2.0.2.
2. Restart*
3. Download driver 1.6.9 and install.
4. Restart
5. Remove driver 1.6.9 using the “Numark Driver Remover”
6. Restart
7. Install driver 2.0.2
8. Restart
You will be forced to restart after the installation of new drivers.
2. Restart*
4. Restart
6. Restart
8. Restart
geposted Fri 09 Dec 11 @ 10:00 pm
Hi i just bought virtual dj pro version and im tyring to connect my numark mixdeck. It doesnt work and im absolutely sure the mixdeck is set to midi and have tried all of the config settings recomended in previous forum posts. Please help. The only thing that happens when i set the mixdeck to midi controller with the approriate settings in virtual dj is slight back lighting in the decks. Im not sure what problems this is stemming from but i really need help. Thanks
geposted Thu 03 May 12 @ 12:39 am
Please ensure that you have the latest drivers and firmware for the MixDeck installed.
Please see: https://virtualdj.com/wiki/MixDeck.html
geposted Thu 03 May 12 @ 4:59 am
