Does the Mixtrack allow you to set up more that one effect per deck. I like how the Hercules Steel allows for up to 12 different effect per deck.
geposted Thu 12 Aug 10 @ 9:13 am
Yes you can control as many effects as you have.
geposted Thu 12 Aug 10 @ 9:51 am
Must say big props to numark with the mixtrack and mixdeck they work flawlessly
geposted Thu 12 Aug 10 @ 10:02 am
So how exactky does it work with it having only one button? Does pressing the effect button turn the EQ kill buttons into effects along with the loop buttons or does the effect button basically cycle thru your effects? The reason I ask is because sometimes I like to mix together a flange, reverd and echo simultaneously. Is that possible with the Mixtrack?
geposted Thu 12 Aug 10 @ 10:28 am
The effects will remain on until you turn them off, you can toggle between the FX using the rotary.
So you can turn several FX on or off. The FX button turns FX on or off. You can also in Virtual DJ Pro map the EQ kills to become FX on off toggles if you want using the mapping scripts. You could perhaps make a definition which states if the FX buton is pressed it will toggle on off but if it is held it will change the behaviors of the other controls.
geposted Thu 12 Aug 10 @ 10:54 am
yo skyfxl....thank you so much for your help! one last thing........... this whole mapping scripts thing.....how exactly is that done and is it something that someone with good experience in mapping would need to do. Or can someone without experience do very easily.
geposted Thu 12 Aug 10 @ 12:03 pm
dont mean to be a pain in the ass just trying not to regret my purchase.
geposted Thu 12 Aug 10 @ 12:04 pm
Why don't you register your software?
geposted Thu 12 Aug 10 @ 12:24 pm
Because the one that i have i got from my brother and it was on his laptop already and he said he had it registered when i asked him and was signing up on here.
geposted Thu 12 Aug 10 @ 12:31 pm
Ok I see, anyways here's a link to the list of verbs VDJ uses, https://virtualdj.com/wiki/VDJscript_verbs.html. For the most part I would say its pretty easy to figure out but when you start getting into macros and such it can get alittle confusing (well for me anyways, lol).
Hope that helps
Huey
Hope that helps
Huey
geposted Thu 12 Aug 10 @ 1:17 pm
so there is no regretting the purchase , since there was no purchase .........
geposted Thu 12 Aug 10 @ 1:23 pm
i meant regreting the purchase of a dj controller that wouldn't perform the way i needed it to.
hey beatbreaker1 thanks a lot bro............it looks complicated but ill give it a try.....trial and error is the way to go.
hopefully by the time I decide to go buy it a map with wat i need will be available......( fingers crossed ) lol
I want to thank all of you that helped answer my questions today....thank you!!!!!!...you guys rock!
Aliasgx
__The Trakformers__
Aliasgx
__The Trakformers__
geposted Thu 12 Aug 10 @ 1:51 pm
skyfxl..........................do u have alll those controllers in your pic...and if so, which would u strongly recommend me to purchase....i am presently using the hercules...thanks in advance
geposted Sat 14 Aug 10 @ 5:32 am
What features are you looking for?
geposted Sat 14 Aug 10 @ 10:01 am
and what is the difference between Mixtrack and Mixtrack Pro? I only can find Mixtrack....
geposted Sun 15 Aug 10 @ 5:43 am
Mixtrack pro features a sound interface more details coming soon...
geposted Sun 15 Aug 10 @ 12:11 pm
Here is my mapping layout for my effects on the MIXTRACK ...
[VIEW/ TICK] [BASS] [MID] [TREBLE]
[EFFECT] (Select) (Control) (Control)
** The notation above corresponds to the effects / EQ layout located on the Numark Mixtrack
Effect # 1 - DELAY - mapped to the [EFFECT] button / utilizes both (Control) knobs {standard effect layout}
Effect # 2 - NOISEBELL - mapped to the (Select) knob / utilizes this same knob to control it and to toggle it on /off since this is also a button
UTILIZES A MAPPED "ALT" KEY ..... (the "SCRATCH" button)
Effect # 3 - FILTER - press and hold "alt" key /mapped to the (Select) knob / utilizes this same knob to control it and to toggle it on /off since this is also a button
UTILIZES A MAPPED "SHIFT" KEY ... (uses both the "VIEW" and "TICK" buttons)
Effect # 4 - BEATGRID - turn on the "shift" key / press [BASS] button
Effect # 5 - OVERLOOP - turn on the "shift" key / press [MID] button
Effect # 6 - GATE - turn on the "shift" key / press [HIGH] button / utilizes both (Control) knobs
Hope this info makes sense ... Licensed Virtual DJ Pro users can PM me for the specific XML mapping modifications for this layout
Also looking for some improvements / suggestions to this as well. :)
geposted Sun 09 Jan 11 @ 5:24 pm
Just added a 7th effect ...
Effect # 7 - ECHO DOPPLER - mapped to the [EFFECT] button / utilizes both (Control) knobs {standard effect layout}
geposted Sun 09 Jan 11 @ 7:11 pm
@Conspired,
I noticed you got all your main effects mapped but see nothing for effect sliders........ Here some script DJDad helped me with to get my jogs to act as "PithcBends, Scratch (acts like vinyl) and last turns my jogs into "Effect Sliders 1 & 2".
Map your scratch button (or whatever free button you want) with this
cycle '$mode' 3 & var_equal '$mode' 0 ? off & deck left vinyl_mode off & deck right vinyl_mode off : var_equal '$mode' 1 ? on & deck left vinyl_mode on & deck right vinyl_mode on : var_equal '$mode' 2 ? blink
and your Jogs with this
var_equal '$mode' 0 ? jogwheel : var_equal '$mode' 1 ? jogwheel :deck left select ? device_side 'left' ? deck left effect slider 1 : deck left effect slider 2 : deck right select ? device_side left ? deck right effect slider 1 : deck right effect slider 2 : var_equal '$mode' 0 ? jogwheel : var_equal '$mode' 1 ? jogwheel
Just food for thought, lol
Huey
Huey
geposted Sun 09 Jan 11 @ 7:20 pm
@ Huey
Actually both effect sliders are there for the DELAY, GATE and ECHO DOPPLER ...
NOISEBELL and OVERLOOP ... I have set to a constant, so I only need to control one effect slider each
FILTER .... is controlled by it's default effect slider
BEATGRID ... doesn't use effect sliders
BUT!!!!!! ... I like the information you presented here and never even thought to go in this direction. So cool ....
Currently I have my jogwheels controlling movement of CGB grids and loop movement (in addition to its default functionality) .... I will wrap my mind around adding your suggestion as well to the Numark Mixtrack.
Thanks as always :)
Thanks as always :)
geposted Sun 09 Jan 11 @ 8:11 pm
