Topic: NUMARK MIXTRACK QUESTION - Page: 2
what is the difference between Mixtrack and Mixtrack Pro?
The MixTrack Pro has a built-in DJ sound card, allowing you to headphone pre-listen.
MixTrack has no sound card (May be a good option if you already have suitable sound card(s), e.g: Numark DJIO.)
what is the difference between the mixtrack and the mixtrack pro??????
Please see the post directly above yours.
do people not bother to research products these days of read the forums?
HELP!! I just purchased a Mixtrack and having some cue issues. I use the mixtrack pro to do a livestream but been hearing my cue mix in my stream. I am using the same laptop that my VDJ and My Mixtrack pro is installed on to stream. Can someone tell me the correct settings? I have tried every possible setting with no luck.
Thanks
>Numark,
I don't know if this is only with my mixtrack or with the whole range, but when I'm fading out the eq's when mixing, there's always a click sound that comes through my monitors from when the EQ controlers are moved out of their set position at the top. Cause other than that, the product is awesome, I really like it.
Any help would be awesome.
Thanks, Jack.
