When you guys say the "skin should match my screen resolution" what exactly do you mean and how do I find out what my resolution is?? Is it where I go to setup my extended desktop?? If so my screen is set to as high as it'll go and I believe its something like 1600 by something. It's only a 15 inch laptop so I'm gonna assume that I have something wrong here? And just let me say that I don't see a difference in CPU usage when the skin is minimized or maximized.
And can you put it in laymen terms please, Thanks for the time
Huey
Huey
geposted Tue 22 Mar 11 @ 1:30 am
geposted Tue 22 Mar 11 @ 9:38 am
Yeah, Screen Res is accessed from desktop just right click on your desktop and choose properties and then settings. Usually just a sliding scale always best to choose highest unless you have bad eye sight.
geposted Tue 22 Mar 11 @ 10:08 am
Thanks Charlie, ok so I was right. Now the next question, do I resize the skin to match that number below the slider on the screen?
Thanks for the time and info
Huey
Huey
geposted Tue 22 Mar 11 @ 10:19 am
In a word, .. yes !
geposted Tue 22 Mar 11 @ 10:25 am
In a word, Thanks! Lol!! Ok ill try it pt and see what happens.
Thanks for the time fellas.
Huey
Huey
geposted Tue 22 Mar 11 @ 10:34 am
