Tell me
In the denon asio driver you can set the buffer size (i assume this is same as latency) currently that is set on 512 sample (11ms)
I am wondering if we should set VDJ 7 to auto latency and move the sample rate within the asio driver.
hmmmmm
hmmmmm
geposted Thu 26 May 11 @ 1:12 pm
I moved both to the lowest possible, with safe unchecked, and then backed off the soundcard till the static went away and have been good ever since. That's how I set up any soundcard I use. Maybe others will chime in.
Huey
Huey
geposted Thu 26 May 11 @ 1:44 pm
I had that problem too. I solved it by going into my laptops power settings and putting everything to the highest performance settings. I noticed when I'm going off battery (barely ever) that the noise comes back. My performance settings when running off battery are set more conservatively so it makes sense.
geposted Fri 10 Jun 11 @ 2:29 pm
geposted Sat 18 Jun 11 @ 5:27 pm
