I bought a pair of Numark Redwaves they are pretty sturdy & sound good.
geposted Mon 02 Jan 12 @ 9:25 pm
Anyone come across the beats by dre fakes? Theres heaps across the internet. Youtube it, you can see people doing the side by side comparison. I was strolling through the markets the other day and so many people were selling them it was crazy. I had a good listen to them and IMO they are an awesome deal for what they are.
Note I am not condoning the purchase of "fakes"
geposted Mon 02 Jan 12 @ 11:40 pm
Budget headphones, come on man you can be that skint! a decent pair of Sony's or something aren't that expensive.
Would never by Numark headphones, it would be like using a Numark mic!
PS, I use 1 cup of a HDJ1000.
The cup with the lead attached lol
geposted Tue 03 Jan 12 @ 11:12 am
@Charlie Wilson - Now that you mention the Pioneer HDJ-1000 headphones, a sales rep at one of the stores I was checking out headphones at did tell me he was a huge fan of the Sony v700, but he bought a pair of these Pioneers and loved them. He mentioned they're comparable to the Sony v700 in quality and the biggest difference was how they're built; they don't break as easy. He said it would be the last pair of headphones I'd buy. Sounded like a typical sales pitch so I walked away, mainly due to the price difference, but also because they were the only set NOT on display and he wouldn't open the box. Guess they might be worth looking into as well.
Thx.
Thx.
geposted Tue 03 Jan 12 @ 6:38 pm
The Sonys are just as good, just buy a pair and when they snap in half dont sweat it just use the one cup, if your a mobile guy you'll be fine.
geposted Tue 03 Jan 12 @ 7:23 pm
I own quite a few Numark products and they are definetly decent, I bought my Numark Redwave's on sale for $50.00 & I am satisfied for mobile use, everyone has there own opinion.
geposted Thu 05 Jan 12 @ 9:35 am
umm so I take it you use a Numark mic as well then lol
geposted Thu 05 Jan 12 @ 12:05 pm
Well unless you've tried them I don't think its right to criticize them in the least bit. We use them in our booths when we do tradeshows all the time.
geposted Thu 05 Jan 12 @ 12:49 pm
Lighten up!
geposted Thu 05 Jan 12 @ 2:16 pm
Charlie you are the 'heaviest' most miserable dude I have ever come across on any forums lol
geposted Thu 05 Jan 12 @ 3:58 pm
I love theses and have a pair for over a year and a half so far
http://www.bhphotovideo.com/c/product/813201-REG/Reloop_RLP221883_RHP_10_LTD_Professional_DJ.html
DJ JAMM
DJ JAMM
geposted Fri 06 Jan 12 @ 3:07 am
What's up Everyone,
In the past I bought so many budget headphones, that I could have bought 2 really good headphones. I've had the Pioneer 1000 for about 5 years. Perfect for me. I will admit when I bought it, within a month, one side broke. It was still under warranty and repaired. No problem since then, but I am now noticing sound difference, isolation issue, & the headband is getting too loose. I'm now looking to purchase the same pair or look at other brands.
Bottom Line, everyone invest in their music & equipment, & should invest in a good pair of headset that meets your budget.
Have fun...
FLeX
Have fun...
FLeX
geposted Mon 09 Jan 12 @ 6:52 am
I've been looking at the Numark Red Waves and after a brief search through google i couldn't find any details about their specs. Not even the Numark website reveals the technical details. I want to know their impedance, sensitivity and max input power.
I get turned off when a manufacture will try to give you a sales pitch on why their product is the best but goes out of their way to not reveal the tech specs.... It seems to me that they are trying to hide something or don't want you to compare with other brands.
Has anyone used the Shure 750DJ Headphones - They are very similar in price the red waves and are very close in specs wise to the pioneer HDJ1000's but $50 cheaper
Shure750DJ
Driver size: 50 mm
Sensitivity (1kHz): 106 dB/mW
Impedance (1kHz): 32 Ω
Max. input Power: 3000 mW
Frequency range: 5 Hz - 30 kHz
Weight: 8oz
Pioneer HDJ1000
Frequency: Range 5 to 30,000 Hz
Impedance: 40 Ohm
Maximum Input: 3,500 mW
Output Sound: Level 107 dB/mW
Unit Type: 50 mm dome
Weight: 9.5oz
Maybe what i'm looking spending isn't in the budget range but more mid range.
Shure750DJ
Driver size: 50 mm
Weight: 8oz
Pioneer HDJ1000
Impedance: 40 Ohm
Weight: 9.5oz
geposted Sat 14 Jan 12 @ 9:51 pm
I have been using the Shure's for about 2+ year's & love 'em.
geposted Sun 15 Jan 12 @ 1:42 am
Hi Nova,
That's a very good point that know one else has mentioned yet, it's ok making them look cool by adding a nice red colour to them but whats the build and spec? usually Numark build inferior products as their built to a budget hence I suspect the reason for not displayed the specs.
Seems Numark only do one lead microphone and that doen't have any spec's with it either.
geposted Sun 15 Jan 12 @ 5:34 am
What Numark Mic are you all talking about?
This one? The wireless? Which does give specs
http://www.audio-depot.com/index.php?main_page=product_info&products_id=2027
Or this one which does not.
http://shop.77records.info/store/product_info.php?language=en&info=p100309663_Numark-Mikrofon-WM-200.html&ref=2
I have always been a Denon DJ by preference. For build, features & quality I have been more than happy with them. If it works for you & is making you money it's all good. Many out there do not like Denon for whatever reason.
I found when I was in the consumer electronics business that every manufacturer makes great & not so great products in their line. Same goes for DJ equipment & brands.
geposted Sun 15 Jan 12 @ 9:00 am
I was talking about Numarks lead mic, I was trying to offer a reason as to why they do not include specs with some of their products.
Was the only reason I could think of, I'm not saying don't use Numark!
geposted Sun 15 Jan 12 @ 10:10 am
I'm new to the forum and just stumbled upon this thread. I was wondering if anyone has an opinion on the Monoprice 8323's for about $22. They get really good reviews elsewhere, like here:
http://news.cnet.com/8301-13645_3-57337747-47/how-good-can-$21.59-headphones-be/
geposted Fri 05 Oct 12 @ 9:53 am
If you're using them daily then I don't recommend any budget pair - you'll be better off in the long run investing in a quality pair such as the Pio HDJ's which are designed for daily abuse.
geposted Fri 05 Oct 12 @ 10:30 am
RELOOP RHP-10, GRT FOR THE MONEY
JAMM
BE GENTLE
JAMM
BE GENTLE
geposted Sat 06 Oct 12 @ 2:30 am
