Because the Pioneer DDJ-T1 is not a natively supported controller (Only a user-made mapping exists), you will need to either purchase or subscribe to VirtualDJ Pro Infinity.
A controller license cannot be purchased a controller that's not natively supported by VirtualDJ.
NOTE: VirtualDJ LE for Pioneer XDJR1 will only work with that controller. it does not support using any other controller. The same also applies to a v8 controller license purchased for XDJR1.
geposted Fri 06 Jun 14 @ 8:23 am
i have failed to download virtualdj le for my controller XDJ R1 ..i need an urgent help pliz . give me a direct link because i lost my cd when i travelled to uganda...thx
geposted Fri 06 Jun 14 @ 10:47 am
you don´t need a cd....if you have a registered licence, just login with the relevant mail and password and you will find the serial and installer by clicking "my account" / licence..
geposted Fri 06 Jun 14 @ 10:53 am
pliz help me with a direct link where i can get virtualdj le
geposted Fri 06 Jun 14 @ 10:57 am
i´m afraid...if you have a licence and no account you should consider to contact the support team.
geposted Fri 06 Jun 14 @ 11:03 am
Please register your VirtualDJ LE serial number to your account. Once you have done this, you can then download it.
If you have any problems then please contact support: https://virtualdj.com/contact/
Users on the forum are not able to help with licensing/billing issues.
geposted Fri 06 Jun 14 @ 11:23 am
I bought the ddj wego controller and I lost the virtual dj le (ddj wego) how to download this
geposted Wed 02 Jul 14 @ 5:57 am
You will either need to contact the manufacturer to see if you can retrieve the serial from them or you can contact support if you need further assistance.
geposted Wed 02 Jul 14 @ 7:39 am
tenho gostado a vossa tecnologia e admiro miuto a forma de sentir a musica gostaria que me dessem os tópicos de como mudar de cor do virtual dj .
Hello. This is the english speaking forum. Please ask your question in english or use a forum of your language. Thank you. [Moderation Team]
geposted Wed 02 Jul 14 @ 9:48 am
I would like to know what that error 4 means because I try to get in to the program and the error is there I put the code # and the same, I have virtual dj pro 7 li is for numark mixtrack pro. Anybody can help me Thanks
geposted Fri 01 Aug 14 @ 2:56 pm
Hello,
please register your serial number of your Pro Full Version here: https://virtualdj.com/users/edit.html (click on my license)
After that redownload a working setup file from the same page.
Greets, Heiko
Greets, Heiko
geposted Sat 02 Aug 14 @ 5:26 am
hi all i have a pioneer ddj ergo i lost my pc including the set up cd but i have the code ,where can i download the set up
geposted Thu 14 Aug 14 @ 8:31 am
i have a ddjwego and a code but i changed my macbook it has no disc room! so i download a VDJLE form this site but when i use it, it still needs me to buy a pro version otherwise its no setting options! what should i do?
geposted Sun 14 Sep 14 @ 3:58 pm
jakovski wrote :
Hello,
Greets, Heiko
Greets, Heiko
geposted Sun 14 Sep 14 @ 4:20 pm
jakovski wrote :
jakovski wrote :
Hello,
Greets, Heiko
Greets, Heiko
i did but after install program its the same problem
geposted Sun 14 Sep 14 @ 4:35 pm
The LE Version does not offer any mapping abillity or settings because it is predefined.
Should be no need to change anything.
geposted Sun 14 Sep 14 @ 5:40 pm
no u r wrong... the problem is i have the program but i have to setting something to make it play music... i just input my wego it doesnt have anything sound... even the track is playing
geposted Sun 14 Sep 14 @ 6:46 pm
Hi guys I wonder if you can help
I have both Virtual dj Le & Pro V8. I use a Numark N4 but with vurtual dj I cant pre listen to tracks with the headphones?? But using Serato I can. I prefer to use VDJ can you help
THX
THX
geposted Wed 17 Sep 14 @ 2:07 am
Hallo i used Virtual DJ LE For the Controler Virtual DJ Beatmix from Reloop.I did a format to my pc and i forget to keep the softwere on backup .The software was on the pacage of the controller and now i have lost the cd and the serial number i didnt signed in on virtual dj as i think.I am here because i asked to reloop support team for my problem and i didnt take any answer.I am asking for a way to take my software back if it possible..
geposted Wed 01 Oct 14 @ 1:00 pm
Please go here to state your issue, and someone will help you.
geposted Wed 01 Oct 14 @ 1:52 pm
