geposted Wed 01 Oct 14 @ 7:50 pm
I purchased a Numark Mixtrack 2 for my son. It came with Virtual DJ LE. Apparently he can't use all functions of Virtual DJ unless he gets the full version. Is this true?
Also the Numark also released a PrimeLoops sampler pack. I wouldn't work on LE also. What should we do?
geposted Sat 11 Oct 14 @ 3:56 am
The LE versions are indeed limited in their functionality. If you want to use functionality that isn't in the LE then you would need to upgrade to use it.
geposted Sat 11 Oct 14 @ 4:11 am
You could buy a "controller license" for VDJ 8 which would enable full use, but specifically for that one controller (whereas the Infinity license allows any controller).
geposted Sat 11 Oct 14 @ 7:45 am
hi i lost my disc and it had the siral number with it and i need it to dowload virtual dj le
and i also have a numark dj3 and i need the disc can you help me
what do i do
what do i do
geposted Mon 20 Oct 14 @ 5:51 pm
We are not able to help you as you have not registered the LE keycode (serial) to a virtualdj.com account in the past. However, you should try to contact Support for alternative solutions. https://virtualdj.com/contact/
geposted Mon 20 Oct 14 @ 5:56 pm
i lost my main account and i can't download virtual dj le for my wego . what's the solution
geposted Thu 23 Oct 14 @ 2:42 am
Please contact Support https://virtualdj.com/contact/
geposted Thu 23 Oct 14 @ 3:01 am
hola me pueden ayudar :tengo contolador hercules control dj air le instalo el maper en el virtual 7 y solo me funciona por 10 minut q debo hacer para q trabaje bien el virtual
geposted Sun 23 Nov 14 @ 2:41 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum (Where available) to post in your own language.
These other language forums can be found at the bottom of the main forum topic list.
geposted Mon 24 Nov 14 @ 7:39 am
Hi & Hello Sir/Ma'am! My Dj controller is Numark iDJ3 with vdj 7 & 8 software....But when I used my controller with the vdj8 in the middle of my mixing always appears the info about the software....Do you have a Free Download Full Cracked with Keygen of virtual dj 8 Sir/Ma'am? Thank you!!!!
geposted Sat 29 Nov 14 @ 2:30 am
If you want to use the software with your controller then you would need to purchase a license:
https://virtualdj.com/buy/
geposted Sun 30 Nov 14 @ 12:12 pm
Hi All,
I purchased the Pioneer WEGO and installed the software on my laptop. I am now in Thailand and my laptop died so I have a new one but I do not have the software disc with me. Is there anyway I can download the LE version to install on my new laptop and work with my WEGO?
I need the software only.
Also if i purchase the PRO version of virtual DJ does the Pioneer WEGO work with this version
Thanks
Thanks
geposted Mon 15 Dec 14 @ 7:52 pm
Hi!
I just got a Denon DJ MC3000 and it's supposed to come with Virtual DJ 7 LE. The disc that was shipped to me was cracked. So I just entered the Serial No. in Virtual DJ 8, which I had, then that told me the code was for VDJ7 and to enter the serial no. on my profile. After I did that I was told I have entered the wrong code, and after trying countless times I got the same response every time. Do I need that disc? I feel like I shouldn't absolutely need the disc, just the serial no. but that's not working either. Please Help.
Thanks
Nic
Thanks
Nic
geposted Mon 02 Feb 15 @ 10:37 pm
@Nic
go here https://virtualdj.com/users/edit.html licences
and add your VDJ serial there, then you can get a V7 LE download, possibly V8 LE
geposted Tue 03 Feb 15 @ 12:23 am
Nic,
If you bought the controller second hand, this is why the serial number is likely invalid as the original owner has probably registered it to their account.
The original owner is not permitted to sell the software with the controller. Only the controller.
In this case you will need to purchase a new license for the controller. https://virtualdj.com/buy/
If you purchased the controller brand new from a dealer then please contact support. https://virtualdj.com/contact/
Thanks.
Thanks.
geposted Tue 03 Feb 15 @ 3:50 am
Hello I bought a Numark Mixtrack 2 for that, I got virtual dj v7.3 limited edition on cd and my mackbookpro doesnt have cd drive I ask how to solve it?
Thank you
Thank you
geposted Sun 08 Feb 15 @ 5:59 am
You can download VDJ 7 LE from your account here.
geposted Sun 08 Feb 15 @ 6:06 pm
I just got a Hercules Dj4Set and I download virtual dj 7 but I don't know how to setup my Hercules dj4set to virtual dj. PLEASE HELP!!!!!!
geposted Sat 21 Feb 15 @ 6:41 pm
My original CD is broken , Software also wash the absence of a full version , how to get back
geposted Sun 22 Feb 15 @ 8:10 pm
