Hi
running mac 10.6.8, vdj 7.0.5, denon mc6000
all stable.
Thinking about upgrade vdj software to 7.4.
Is ist possible to downgrade to 7.0.5 after the upgrade ? If "something" goes wrong.
regards
Steen
all stable.
regards
Steen
geposted Sun 12 May 13 @ 2:47 pm
Yes, you can simply install v7.05 again over the top of v7.4
Alternatively (Recommended), make a copy of the VirtualDJ Pro application and rename it VirtualDJ Pro v705 - Then when you install v7.4, you will get a new application icon for it and can then run either by clicking on its icon.
Make sure that you take a full backup first before upgrading (See http://www.virtualdj.com/wiki/How%20do%20I%20backup%20my%20VirtualDJ%20database%20and%20settings.html ) and ensure that you have plenty of time to test it (Don't upgrade just prior to going to a gig.)
geposted Sun 12 May 13 @ 5:28 pm
