yandy82 wrote :
Are you on a Mac or a PC?
I run mine on a Mac and running smooth with VDJ. 8+ hours at a time.
On a macbook pro 17" but running bootcamped under windows 7
geposted Mon 16 Sep 13 @ 7:26 pm
Has anyone mapped the 2 effects buttons above each channel ? I'd love to be a able to load 8 new samples in each button
geposted Mon 16 Sep 13 @ 9:01 pm
i have a proplum with virtual dj shutting down when i use effects on my pioneer ddi sx any help please
geposted Sat 21 Dec 13 @ 9:50 am
also even when i start up vj it shuts down
geposted Sat 21 Dec 13 @ 9:51 am
@djbillc
I have the DDJ-SX and have no problems using it with VDJ.
Is VDJ not starting up even with the DDJ-SX disconnected from your computer?
geposted Sat 21 Dec 13 @ 10:33 am
yes it starts up but when you use the fx buttons it just shuts down and some times when it shuts down you start it back up and as soon as you touch any button it shuts down i have put new soft wear on but it just dose the same thing all the time
geposted Sat 21 Dec 13 @ 1:53 pm
yes when pioneer ddj is not on it works perfect i alsl have the vms 4.1 from adj and get no problums
geposted Sat 21 Dec 13 @ 1:58 pm
I would suggest updating the firmware for the SX and use at least VDJ 7.4.
Are you using it on MAC or PC?
I am using a Mac and everything works fine.
geposted Sat 21 Dec 13 @ 2:26 pm
useing a mc yes i'v updated firme wear but still dose it
geposted Sat 21 Dec 13 @ 2:41 pm
i'm running virtual dj pro mate
geposted Sat 21 Dec 13 @ 2:42 pm
If it only happens when you try to use FX, what FX do you have in VDJ? What FX are you trying to use?
Maybe that particular effect is incompatible in some way.
Does the DDJ-SX work OK when using Serato software?
geposted Sat 21 Dec 13 @ 3:04 pm
Did you try the instructions in this link?...
https://virtualdj.com/wiki/DDJ-SX.html
geposted Sun 22 Dec 13 @ 8:45 am
Hi Groove, Yes, The DDJ-SX works perfect in Serato dj, all the sound effects, etc work without a single issue. In virtualdj if you play ANY sample, from the built in, to the on the fly created samples from a song, it will play it at 100% volume. Once you play it, it is normalized for only as long as you are playing the SAME track on that deck. Once you change music on the deck, the sample volume is reset to 100%. I do not use any samples when running my unit at a club.
geposted Sun 22 Dec 13 @ 11:41 am
DJ Koz wrote :
is this a brand new update?
geposted Sun 22 Dec 13 @ 11:44 am
The DDJ-SX is natively supported. There are settings and extra tools to get it working properly. The sample volume is tricky. As I used it more and more I am able to know what the loudest I can go is before it's ear bleeding loud.
geposted Sun 22 Dec 13 @ 5:17 pm
whats up fello DEEJAYS!
IVE BEEN USING VIRTUAL FOR ABOUT 7 YEARS NOW
ALL GIGS .... BAR'S OR PRIVATE PARTYS .. AFTER THE CORRECT CONFIGURATION
IT WORKED ABSOLUTELY GREAT WITH MY PIONEER DJM 5000 MIXER ,
VIDEOS , MUSIC , KARAOKE , GREAT GREAT GREAT !!!
I JUST BOUGHT THE PIONEER DDJ SX CONTROLLER CAME WITH SERATO , THE FACT IT DONT READ
WMA FILES SUCKS!!!! I HAD TO CONVERT HALF OF LIBRARY TO ITUNES IN ORDER TO PLAY .. TERRIBLE
SO I FIGURED , ILL USE VIRTUAL DJ 7 PRO WITH MY DDJ SX AND JUST LIKE COMMENTS MENTIONED ABOVE
IT FREEZES UP , NO RIGHT SCRATCHING , GAIN STICKS , ITS DRIVING ME CRAZY , LAST NIGHT I WAS AT WORK
DJ'ING AND IT FROOZE UP ON ME AGAIN!!!!, THANK GOD I HAD MY HANDY DANDY GIG APORT EXTERNAL USB SOUNDCARD
I RAN VIRTUAL THROUGH MIXER ONLY,, CAN SOMEONE PLEASE HELP ME OUT ?
IM RUNNING SONY VIAO WINDOWS 7 , 4GIG - 500 HD AND I7 PROCESSOR DO I NEED MORE MEMORY ?
I HAVE NO PROBLEM USING MY PIONEER DJM 5000 W/VDJ PRO 7 BUT THE DDJ SX IN WHITE LOOKS
NICER!! BUT NOT FULLY COMPATABLE WITH VDJ PROGRAM :( THANKS IN ADVANCE DJ SAL BKLYN NY
geposted Mon 10 Mar 14 @ 12:43 am
1) Turn OFF the CAPS.
2) Please read the entire thread
3) Now please let us know your EXACT issues.
4) DDJ-SX is one of the most popular controllers for VirtualDj right now and 100's of users (myself included) have it working flawlessly.
geposted Mon 10 Mar 14 @ 6:15 am
I was asking djbillc about his issue with FX.
geposted Mon 10 Mar 14 @ 6:32 am
any chance you could go over how you have made the sampler deck playable w/ddj-sx.
geposted Mon 10 Mar 14 @ 7:56 pm
Phantom - you mentioned that you and 100's of other users are using DDJ-SX with Virtual and it works " flawlessly " . I have the Denon MC6000 now and my unit is getting worn and needs replaced. I'm considering getting a DDJ-SX but i've never used a controller before that was built for another software. Is everything going to function properly with Virtual DJ or are there features on the controller that are not going to work at all or properly? I just want to make sure i don't get something i'm not happy with. I should also mention i'll be using this with a PC. Someone mentioned above that it seems PC's running the DDJ-SX and VDJ have issues. So do you use yours with PC or Mac? Thanks in advance for any advice/recommendations!
geposted Tue 18 Mar 14 @ 3:10 am
