No problems on a PC (Intel - Win 8.1) using DDJ SX.
You can use the DDJ SX without any restrictions with VDJ.
geposted Tue 18 Mar 14 @ 4:42 am
I'm using a Windows 7 x64 system.
I also own both the MC6000 and the SX.
You should not have ANY issues with the SX.
Most of the complaints for the SX are from users that don't realize how the unit works:
E.G.:
It's a controller! This means that the gain knobs for instance behave differently than a standard hardware mixer. If you used EXT MIX with your MC6000 (in order to have 4 decks) then you should be familiar with what I'm saying. If you used INT MIX and therefore you had DENON working as a hardware mixer then the gain knobs work different.
On the SX you must move them to come in "sync" with the software position before they start to control the actual gain.
Other than that the only "unresolved" (but mostly fixed) issue is that the sound may crackle if you try to scratch with BOTH jogs at the same time.
E.G.:
geposted Tue 18 Mar 14 @ 7:35 am
Awesome thanks for the response guys - I think the DDJ-SX is going to be my new piece of hardware making the MC6000 my backup. I'll come back here if i run into any problems!
geposted Tue 18 Mar 14 @ 11:59 pm
"I agree.... a lot of the same issues here"
I want to say: me too !!!!
coque galaxy s4
coque galaxy s4
geposted Wed 19 Mar 14 @ 3:00 am
If one already uses a controller say a Vestax Typhoon, how would one be able to switch and use the pioneer? Would I have to reinstall VDJ? I use a PC running on windows. My Vestax Typhoon cannot function without the Vestax USB hub it was provided with in the bundle and when the wire is even moved, it freezes the entire program and stops the music. I even changed the wire itself, I'm beginning to think it's the hub/controller. And it only works in one of the specific ports as well on the ASUS HP 2000
geposted Tue 08 Apr 14 @ 5:34 pm
You should be able to unplug the Vestax and plugin in the Pioneer.
Install the drivers, set up your audio config and your away.
geposted Tue 08 Apr 14 @ 5:39 pm
You do not have to re-install VDJ. Some computers require you to use the same usb port, that you installed the drivers with. When you say hub, do you actually mean the usb port, on the controller?
geposted Tue 08 Apr 14 @ 8:46 pm
Hello Everyone
I use 17" mac VDJ 7.4 and Pioneer DDJ-SX
I have lots of mapping issue Mapping on Actual DDJ-sx is not same az Manual for Mapping Ver 1.2.1
for example
you can't tern off and On Slip Mode
It looks like Slicer docent work right
I Also have issues with effect
any manual to teach you mapping of this unit
thanks!
for example
thanks!
geposted Wed 09 Apr 14 @ 3:25 am
Are you trying to map this controller for customization or just to get it running?
Because there are already good mapper for the SX in the download section:
https://virtualdj.com/addons/controllers.html?category=best&order=default&search=pioneer
geposted Wed 09 Apr 14 @ 3:37 am
