Forum: VirtualDJ Skins
Topic: [NEW] [VDJ8] TaylaMadeVideo
DOWNLOAD HERE
A collaboration between Tayla and myself on this one.
A super video skin aimed for use with controllers.
v1.1.0 - 15/05/14
Added optional Rhythm Waveform
As always feedback and comments welcomed.
geposted Wed 14 May 14 @ 9:47 pm
Well done guys, could be my number 1 skin but personally I need the waveform back at the top as it enables me to set the cue points more accurately, can't work without that! Would also like the browser & sample search boxes to be taller but could work without that! Thumbs up for the clock. Go on lose a bit of browser high and bring the waveform back, this is the nearest to perfection for me as a video playing guy.
Updated added - see first post.
That's quick Dan thanks. Is there a way to activate the split option?
Not implemented yet that. Can be done though.
Which split are you refering to. The one where you have deck 1 above deck 2.
Or where you have two scratchwaves running?
One above the other please, on Altern8 you call it vertical split on BlacksheepHD under change wave you call it split.
as request screen shots of the clock going, its when its on full screen it goes, thanks in advance for the help, Chris
Ok - looks lie the logo is being resized and covering the clock.
Just uploaded a new version which hopefully will fix it - but i can't test on your resolution.
Please download again and let me know whether the issue is resolved.
Thanks
Its all working perfectly now with the updated skin, thanks for getting back to me so quick and fixing, amazing!
No problem!!
Pleased you like the skin!! ;-)
