Forum: Old versions
Topic: Cannot Log In - Page: 1
Every-time I log in on each computer will not log in at all ????
geposted Mon 27 Apr 15 @ 9:33 pm
Any Antivirus installed ?
geposted Mon 27 Apr 15 @ 9:36 pm
Yes Norton. I just turned everything off still nothing
geposted Mon 27 Apr 15 @ 9:42 pm
I would try to uninstall Norton completely and restart my computer, just to ensure that this is not the case (even though Norton is well known as a killer lol)
check your firewall too.
geposted Mon 27 Apr 15 @ 10:27 pm
Windows firewall????? or Norton???
geposted Mon 27 Apr 15 @ 10:50 pm
I'd check both...
geposted Tue 28 Apr 15 @ 3:18 am
RobRoyPRO InfinitySenior staffMember since 2012
Please lauch start button/ and use the command string
ping live.virtualdj.com
what kind of response do you receive ?
geposted Tue 28 Apr 15 @ 4:05 am
Dunno, I cannot read what it says it shuts down. I do see replys
geposted Tue 28 Apr 15 @ 7:57 pm
type "cmd"
select the cmd.exe
there should open a window with a dos promt
then try again
window should not shut down
please check also if you router blocks any ports ( VDJ uses Port 80 by default)
you can unplug the router to reset
geposted Wed 29 Apr 15 @ 3:58 am
BTW: Are you trying to login with your Google ID ?
geposted Wed 29 Apr 15 @ 4:12 am
It says "is not a recognized as an internal or ext command.....
geposted Wed 29 Apr 15 @ 8:14 am
Which OS ?
geposted Wed 29 Apr 15 @ 8:16 am
Ok got it to work.
I have received a reply for all four
geposted Wed 29 Apr 15 @ 8:17 am
Edit: Ok, nevermind...
geposted Wed 29 Apr 15 @ 8:18 am
Running Windows 7
geposted Wed 29 Apr 15 @ 8:20 am
able to get this screen ?
geposted Wed 29 Apr 15 @ 8:23 am
Yes, I got that. I did ping it and did get all four replies back. So that's a good thing, right? Lol
geposted Wed 29 Apr 15 @ 8:41 am
depends on the IP that replies
screenshot might be helpful
geposted Wed 29 Apr 15 @ 8:44 am
I will do that. I will have to do that later on today. :)
geposted Wed 29 Apr 15 @ 9:03 am
geposted Wed 29 Apr 15 @ 5:30 pm
63%
