So you can access Authentication from your machine but not from VDJ, it has to be a firewall.
geposted Wed 29 Apr 15 @ 6:18 pm
But where, I have turned off Norton, is there any where else?
geposted Wed 29 Apr 15 @ 6:59 pm
I looks like it has to be a Windows thing. I just re installed Windows on my lappy, I had Norton installed and it worked perfect. Then what ever windows updates It had to do wiped it out. Again locked out where I cannot sign in.
geposted Wed 29 Apr 15 @ 7:59 pm
Windows defender running? (long shot)
There is Windows firewall too, win key search "fire"
geposted Wed 29 Apr 15 @ 8:13 pm
I got that, I have gave access to Virtual DJ.
How do I turn it off then?
geposted Wed 29 Apr 15 @ 9:42 pm
You shouldn't need to turn it off, just give V8 inbound and outbound permision
geposted Wed 29 Apr 15 @ 10:05 pm
It only shows up with the inbound.
I do not see it on the outbound
geposted Wed 29 Apr 15 @ 10:22 pm
Well as a start disable windows FW completely and try log in, if that works enable the FW and make an outbound rule.
geposted Wed 29 Apr 15 @ 11:47 pm
possibly your router blocks the Port VirtualDj is using by default ( 80)
Try to unplug the router from the electric power, wait half a minute and pugin again.
Router should reset.
geposted Thu 30 Apr 15 @ 12:57 am
Please...
Are you trying to use your Google ID to login ?
geposted Thu 30 Apr 15 @ 4:06 am
Got it. It was Google was the issue.
I was able to login with the virtual DJ log in
geposted Thu 30 Apr 15 @ 8:14 am
FYI:
Google changed something on their API.
Google ID logins will work again from next beta!
geposted Thu 30 Apr 15 @ 9:46 am
