I need a small controller for a gig, a little dive that doesn't have much room. This is the first time I've ever played at a spot that didn't have room for a full setup, lmao!!
Anyways the Denon MC4000 looks perfect for what need. Anybody used one with VDJ?? If so how well did it perform?? How do the jogs feel when scratching? How do the pads feel??
Any info would be greatly appreciated, Thanks!!
geposted Thu 03 Mar 16 @ 12:59 pm
I have a mc6000 (4 chan version if you like), and its been great for mobile work, great build quality, nice and compact and it has always worked well with VDJ
geposted Thu 03 Mar 16 @ 1:27 pm
Thanks but I asked about the MC4000 not the 6000 which I don't really like because its just to small and feels super cramped.
geposted Thu 03 Mar 16 @ 1:36 pm
Love my Denon MC4000 great sound quality
geposted Thu 03 Mar 16 @ 1:46 pm
I went from a Numark Ns6 to the 4000 and I am super happy with it. I dont scratch much but all of the other features are solid. I dont find it cramped at all the only thing that does bother me is when i nudge the left platter when mixing sometimes I hit the pitch control but other than that I really like it. Hope this helps.
Dave
Dave
geposted Thu 03 Mar 16 @ 7:31 pm
Thanks Dave, that's what I wanted to hear. I'll grab one Saturday after I get back into town.
geposted Thu 03 Mar 16 @ 9:00 pm
Well I just picked it up and this thing is perfect for what I need it to do!! Solid little controller and the jogs don't feel bad at all.
Thanks for all the input fellas!
geposted Sat 05 Mar 16 @ 5:48 pm
I would like to know, if it works well with video ??
Tuesday will have a mc 4000 and not how it works with videos.
Could you tell me something about that ???
VDJ change last night 8 to VDJ 7
I happened to some videos froze with mc 3000 and VDJ 8.1
(for example Mark Ronson - Uptown Funk ft. Bruno Mars)
format, supports avi xvid
with VDJ 7 mc 3000 and worked well,
I'm afraid to switch to mc 4000 and not work with VDJ 8.1
thank you
gabriel
thank you
gabriel
geposted Sun 06 Mar 16 @ 12:30 pm
Videos is pretty much all I do and so far its been good with the videos.
The only thing I don't like about it, is there's only 4 sample pads. I'll have to go back and make sets of 4 for when I'm using the unit by itself. There's room for at least 4 more pads, lol, and I can't change the echo timing on the microphone.
Other then those I like this unit, simple and to the point.
I will say I'm not used to how the internal gain works and I find myself constantly adjusting them. I've went from -3 down to -6 and my VU meter still seems to hit the red. I'm not even sure if the VU meters are that accurate anyways or maybe I'm old school and depend on them to much.
Either way ill give myself some time to get these things worked out before it ever leaves the house.
And 1 last thing, I need to see if Phantom can make a SliverSleek version for this unit also, which I've asked already because opening the multi fx's doesn't work and I've screwed up the mapping a few times already trying to change things around already.
geposted Sun 06 Mar 16 @ 1:21 pm
I thank you for your time to answer.
I like what he says.
one last question...
As used latency ??
216 or 512 ??
Thanks again
As used latency ??
216 or 512 ??
Thanks again
geposted Sun 06 Mar 16 @ 1:49 pm
Latency is set to "automatic" and I on a Mac, not sure if that makes a difference.
geposted Sun 06 Mar 16 @ 1:55 pm
okay thank you very much for your time
Best regards
Best regards
geposted Sun 06 Mar 16 @ 2:49 pm
beatbreaker1 wrote :
I can't change the echo timing on the microphone...
I could be wrong but see this:"39. ECHO. Use this button to enable/disable the Echo Effect on both Microphone Inputs. The amount of the applied Echo Effect is controlled from the front panel of the unit. "
For gain I use auto+remember and hope you get the multi fx to work "Hold SHIFT down and then press the TAP (32)"
geposted Sun 06 Mar 16 @ 4:03 pm
Hey Thanks ohShit, what I mean by "timing of the echo" is change wether its 1:1 or 1:16 or 1/2 beat. Kinda how you can change the echo within VDJ.
Yeah I've switched to auto+remember and things sound better. Used to using an external mixer, lmao!!
As for the multi FX, I think Phantoms code is different then most so holding the shift plus tap doesn't really change it on the screen. It changes on the controller just not on the screen. Sometimes I need to see a parameter so I switch between single and multi FX.
But yeah I'm digging this little guy.
Anybody got any info on a backpack for this thing??
geposted Sun 06 Mar 16 @ 4:27 pm
Do you have a skin for this controller? I hope someone make one with large numbered Cue points like Fruit's skin.
geposted Sun 06 Mar 16 @ 9:44 pm
No I don't have a skin, I just use SliverSleek.
geposted Sun 06 Mar 16 @ 10:27 pm
Here You Go: Watch it At 2:08 he talks about the vu meters / https://www.youtube.com/watch?v=vXyXSGjeT9o
geposted Mon 07 Mar 16 @ 1:15 am
Thanks Tyme, got my gain issues all sorted out.
Just need to get this mapping XML to match the SliverSleek skin and ill be golden.
geposted Mon 07 Mar 16 @ 1:51 pm
Can MC4000 VU meter be Master meter , not Left player left meter, right player right meter? Demo'd it in store but not bought yet..
geposted Tue 12 Apr 16 @ 1:04 pm
That a great question and a script to toggle between VU and master meter?
geposted Tue 12 Apr 16 @ 1:35 pm
